Crafts & Hobbies Logo
Sune Kapp Posted on Feb 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gluestick started to melt in my glue gun and now if i press the trigger nothing comes out. My glue gun heats up but i cant get anywhere with this? Waht can I do?
  • dennieLodon
    dennieLodon May 09, 2022
    Boiling water can soften the glue here. Try just hot water first, working it into the glue and washing it away...
Ruth summersides
Level 3:
Genius:
  • Master 1,493 Answers
  • Posted on Feb 24, 2019
Ruth summersides
Master
Level 3:
Genius:
Answers
1493
Questions
Helped
363362
Points
2425
If your glue melted inside then there is something wrong with your glue gun. You could try putting in another glue stick and see if it will push through. If you live in North America, you can get cheap glue guns at any Dollar store. But if you are talking about a big glue gun for building materials then go back to where you bought it and get help there.
this u
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 14, 2019
this u
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
508
Points
6
In my opinion, get a new glue gun. if the gluestick is melting the gun, I think a few bucks would be worth the fix.
5 Related Answers
Anonymous
  • Posted on Dec 13, 2009
SOURCE: When heater is on, there is a smell, as if
heater core most likely is the smell kinda sweet at all ?
Testimonial: "Quite helpful; leads me in a direction that I would not have thought of"
sonicboomele
sonic boom electronics
  • 1557 Answers
  • Posted on Dec 07, 2010
SOURCE: I have a glue gun
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
cdroari
  • 16 Answers
  • Posted on Jan 03, 2011
SOURCE: Cold heat glue gun directions??
Hi There,
Just flip the switch either forward for a brighter light or towards the back for a dimmer light wait 2 mintes and you're ready to go Unless of course its like mine & just want to be a dim flashlight not a glue gun.
John Trevino
  • 1420 Answers
  • Posted on Jul 21, 2012
SOURCE: DeWalt D51822 Framing Nailer: Replaced the trigger valve and air is still coming from the nose of the gun. I would think no air should get past the trigger valve until pressed. What's wrong?
Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer. Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. Good luck with your repair
Anonymous
  • Posted on Oct 24, 2012
SOURCE: PowerShot staple gun model 5700m is jammed
There is a silver screw near the back bottom (where you load staples) and you must unscrew it. Completely remove the small bolt and the silver base will pop right out. This base is the track where the loaded staples sit while in the chamber. Just remove the jam and re-install in the reverse order. Works like a charm now.
Idea as to cost of this and how it works please
The cost of a glue gun varies between $5-$20 for a good one.
The glue gun works based on heat, in the front of the glue gun there is a heating element, once you install the glue cartridge and press the trigger the glue cartridge is pressed thru the heated element who melts the glue forcing it thru the front nozzle
When i push the handle on my glue gun no glue is coming out
The glue gun heats the glue and melts it. It is the only way it can come out since it is solid otherwise. If the gun is not getting hot enough the question is why and the answer must revolve around the heat. Is there an on/off switch that is not working right, is the gun getting hot? Is power actually getting into the glue gun? And finally has the heating element failed? It is a pretty simple devce so if it is a cheap one and just doesn't work the less aggravating and inexpensive solution, after seeing why it isn';t functioning, is to buy a replacement.
How can I fix my 3M scotch-Weld AE II Glue gun that drips glue at the tip
I have the same problem. I find pulling the gluestick back slightly between trigger pulls helps
Need the instruction manual for a Stanley GR100 glue gun
I do not believe there is a manual. there are instructions on the package. Insert the glue stick and turn on the gun. When the glue melts and the trigger moves glue will come out the front tip. This model has 2 temperatures so if it delivers too fast or runny you can lower the temperature. You pull the trigger to push the glue stick into the heating element to melt the glue. It is pretty straight forward. As the glue stick is consumed you stick in another glue stick. I suggest testing on something before using on your project. Do be careful of the hot end. It will definitely burn you if you touch it and the glue coming out is nearly as hot as the metal.
Hi, can't get Stanley dual melt glue gun to
some users have complained that the trigger fails. when this happens, the glue will not heat up. if it seems to be a problem with the trigger and the gun is relatively new, i would try to return it and get a new one or get your money back
My Adtech glue gun heats and melts stick but nothing comes out the nozzle???
sometimes the trigger can be very hard to pull. if the glue is melting but not coming out the nozzle, where is it going?
I have somehow realeased the trigger so it is not pushing the glue forward but i cant seem to open the glue gun up 2 fix this problem?
there should be small screws near the handle so that you can split the casing into 2 halves. then look for the spring that regulates the trigger
How do i insert glue stick in to my emhardt electric glue gun
Insert the glue stick into the back of the gun. After doing this plug in the gun and allow it to heat up. When the gun reaches the correct heat level you will be able to pull the trigger of the gun which will pull the stick into the gun. This will only happen if the gun is hot enough.
2answers
Glue stick is stuck in glue gun and can't be removed.
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Glue Gun Support
Plug the glue gun into an electrical outlet. Make sure it is placed in a secure place, away from flammable items. As the glue gun heats up, a little bit of glue might drip from the end so you won’t want to leave it on a wood table or on carpet. Insert a glue stick into the back of the glue gun. If the glue gun already has a glue stick in the chamber, keep a second one in reserve nearby. Gather the materials you want to glue together. Hot glue works exceptionally well on thick fabrics, dried flowers, Styrofoam, wood and plastics. Since it leaves a thicker residue, it is not the best choice for thin papers, fabrics and ceramics. Check to see if the glue in the gun has melted by squeezing the trigger slightly and touching the tip to a test piece of paper. If the glue comes out easily, the glue gun has heated up fully. If the trigger is hard to pull, wait a minute more for the gun to heat more completely. Pick up the glue gun and squeeze the trigger slightly while you draw a thin line on one side of the item to be glued. Immediately place the other object to be glued on the glue line, pressing firmly. Hold the two pieces together for about 15 seconds. Test to see if the item still holds when you remove one hand. Let the item set for a few minutes in order to “cure.” Once the glue has dried fully, use a fingernail to scrape away any of the excess glue.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
