SOURCE: Need PUK code, T-Mobile SIM is deactivated (cancel line)
WARNING
Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself.
SOURCE: my nokia 3110c not working properly
Clean and dry the battery terminals, check if the battery has swollen which indicates poor battery, reset all the settings to factory default, possibility of bad memory cells (memory card), it seems the handset is still in warranty period, contact nokia customer care for free repairs or replacement.
SOURCE: my nokia e5 cellphone lost
There is GOOD news and BAD News....1st the bad news, your phone is lost and you will never see it again. The good news is that you can contact your service provider and have the handset disable by giving them the IMEI number.
I have yet to hear about a cell phone company that would trace a lost/stolen cell phone. Hopefully there was an insurance policy which covered lost/stolen phones; if not a replacement is out of pocket.
SOURCE: I have nokia e5 i forget my loce code i need master code nokia e5 please help me
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
SOURCE: setting the date and time
No need to remove part of the camera case. This camera (Power Shot A510) does have a backup battery that is easy to get to. Under the rubber flap where you connect the cable, there's a little door you can pull out with your fingernail. There is a CR1220 battery - can be found at any jewelry store, as it is a watch battery. I replaced that and viola! No more messing with the date/time every time it powers off/on!
Warning :
Do not enter any wrong unlock codes on your Nokia E5 mobile phones. If
you enter over a certain amount of wrong unlock codes on your Nokia E5
mobile phone, your phone may get hard locked and sometimes become
unusable.
1 - Switch on your Nokia E5 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E5.
3 - Compose #pw+CODE+1#.
4 - The Nokia E5 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E5 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E5
Each Nokia E5 mobile phone has an unique unlock
code. You can buy the unique unlock code for your Nokia E5 mobile phone
using the form above.
