Computers & Internet Logo
Hi there, I have forgotten my admin password on Sharp DX-2500 printer now I unable to login as a admin and can not change anything So anyone give suggestion or guide how to fix the problem ?
3 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Sep 15, 2008
SOURCE: Solution to forgotten password
the only way to get in through an admin password is to repair windows using a windows cd
Anonymous
  • 87 Answers
  • Posted on Oct 20, 2008
SOURCE: Password recovery
http://www.securecomputing.com/techpubsRC.cfm
Anonymous
  • 34 Answers
  • Posted on Apr 12, 2009
SOURCE: unable to login to laptop due to forgotten login password
First thing you can try is:
1: When booting up the laptop Press F8 until you see a screen show that has an option to boot in "Safe Mode"
2: Once it has finished booting up you can Select Administrator and hopefully there is no password set.
3: If there is no password set then login as Administrator and goto "Control Panel", Select User Accounts and change your daughter's password to something she wont forget ;p
if that fails then you can try this
http://www.lostpassword.com/
Offers a program that resets your passwords.
Hope this helped.
How i restore default admin password on a Sharp MX-M452N
Download the manual here: http://dl2.opendrivers.com/dl_file.php?dl=dl2&brand=multifunction%2Fsharp-electronics&file=MXM282N-M362N-M452N-M502N_OM_Online-Manual_GB.pdf&check=a35c9re0e86ed5&driver=cs6f4548 dl2 opendrivers com
tip
How to Reset Windows Vista Administrator Password with Three Simple Methods?
Have you ever experienced Windows Vista administrator password forgot? Absolutely, there is nothing worse than forgot your Windows admin password when you have a great deal of work to do on your PC. Even though you can enter your computer with a standard user account, you still could not download anything and install programs on your PC. Therefore, how to reset or recover Windows Vista administrator password efficiently?
Here we will show the top three easy and efficient Windows Vista admin password recovery methods to anyone who have Windows Vista admin password forgotten issues.
Method 1: Reset Windows Vista administrator password on safe mode
Preparation Time: about 10 minutes
Pros: Simple and do not need third party tools
Cons: Need an available admin account on your Vista PC
You can reset Vista administrator password on command prompt with an available admin account to enter safe mode first. If you have another Windows Vista admin account, try these steps below:
Step 1: Press F8 when your Windows Vista PC is booting. You will come to the Advanced Boot Options. Then choose Safe Mode with Command Prompt and press Enter.
Step 2: Enter safe mode with an available admin account.
Step 3: Type "net user" and press Enter. The command prompt will show you all accounts on the Windows Vista PC.
Step 4: Type "net user Paul 123" (Paul is the locked admin account's name and 123 is the new password) and press Enter. Now you have successfully created a new password on the locked admin account.
Step 5: Type "shutdown -r -t 00" and press Enter.
Your Windows Vista PC should be rebooted automatically and then you can logon Windows Vista with the new password.
Method 2: Recover Windows Vista administrator password with freeware
Preparation Time: More than 30 minutes
Pros: Free and do not need to change the forgotten password
Cons: The freeware should not work if the password is too long
Ophcrack is freeware for Windows password recovery. This software can help you to recover your forgotten Windows Vista admin password. So that you can regain access your admin account without changing the password.
Ophcrack is used to create a Windows password recovery disk. You need to boot your computer from the disk to recover your password. You can follow these easy steps:
Step 1: Download Ophcrack
Step 2: Burn a Windows password recovery disk with the freeware
Step 3: Recover the forgotten Windows Vista admin password with the disk
You can logon Windows Vista with the old password now.
Method 3: Reset Windows Vista administrator password with shareware
Preparation Time: less than 10 minutes
Pros: Fast and 100% reset the forgotten password
Cons: Not free
Windows Login Recovery is easy-to-use shareware to reset forgotten Windows password, including administrator password and other standard users' passwords.
Unlike Ophcrack, Windows Login Recovery is designed to reset the forgotten password. No matter how long and how complicated the password is, this software can 100% reset the forgotten password in few minutes. All you need to do is just three steps:
Step 1: Download Windows Login Recovery
Step 2: Burn a Windows password reset disk with the shareware
Step 3: Reset the forgotten Windows Vista admin password with the disk.
These three Windows Vista administrator password recovery solutions are helpful for us to resolve the Vista admin password lost problem. Now, you are no more Vista admin password forgot matters.
on Jun 24, 2010 • Computers & Internet
1helpful
1helpful
How do you reset the admin password for web login access on the Sharp AR-M237?
You must delete the printer and all software and reinstall. maybe a Tehnician can be PERSUADED to give you the default passwords.
ACER 5630-6288 Win Vista Home Premium Admin Password forgotten
yes there is
login with ur normal user profile
go to run>>type cmd
in the black box...
type net user administrator
it will give u options to change the pwd for administrtaor
1helpful
2answers
Forgot password and unable to do anything now
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
2answers
Forgot password have reset but still wont let me in.
First reset again your router to factory settings, just in case. Do this by pressing the tiny button at the back of the router with a pencil, this works for most of the routers. Then check the router manual or go to factory website and find out default setting for admin and password. some router works with 'admin'/'admin' or 'admin'/'1234'. check factory website.
hope this helps.
13helpful
5answers
I forgot my Administrator Password
Forgot Windows XP admin password? Take it easy, Windows Password Recovery Tool 3.0 will help us reset password efficiently by creating a password reset disk!
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
