I have tried the Control lock reset several times. I have tried a hard reboot of the system. Unplugged the machine for 10 min plugged back in waited 90 seconds and powered back on still gives LOC Does anyone now an easy fix for this?
The control panel is locked. This is a safety feature on some models to keep children from pressing buttons and starting the machine. The USE and CARE manual will tell you how to disable the control lock. If the control doesn't unlock the have the customer take the machine back and get a Speed Queen. The ECU is faulty on the Maytag. I'm seeing lots of appliances from Whirlpool that don't work new out of the box at present.
SOURCE: Control Panel
I believe the DRAIN/SPIN button on the Kenmore Elite HE3 will clear a locked control panel if you hold the button in for 3 seconds. This is actually a safety feature to keep small children from playing with the buttons and allows the consumer to lock the control panel. I hope that's all the problem you have and that it is not a control panel failure. Let me know if this helps. PS The matching Kenmore Elite Dryer uses the AUTO DRY LEVEL button for the same feature.
SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
SOURCE: "Warming up Please wait" error
Suspect the toner heating element (fuser) may be malfunctioning. Dell may be able to walk you through a "hard reset" that involves opening the front door, turning on an off the printer with certain buttons held down, etc.
SOURCE: Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
