Question about Hitachi Garden
What are causes for loss of power in my hitachi RB24eap leaf blower?
    Master:
  • 403 Answers
There are many possibilities. contaminated fuel, wrong fuel oil mixture. air leak in fuel line, carburetor contaminated, or needs adjustment, choke problems, throttle problems. Try a small engine mechanic.
Posted on Feb 13, 2019
  • Hitachi Master
  • 788 Answers
Does it start and run ok for awhile and then gradually looses power?
As a test, loosen fuel cap and see if problem goes away. If you find it makes it better, then fuel tank vent is blocked.
Posted on Feb 14, 2019
  • Rob Heffner Feb 14, 2019
    No it continuously runs slower the entire time!
  • Carl Rock
    Carl Rock Feb 14, 2019
    Ahhh... So it does not accelerate when throttle trigger is pulled? If yes, then throttle linkage does not functioning. Could be it has disconnected at the carburetor or more likely something not right inside throttle housing.
    If not connected at carburetor, the trigger would not return to idle position. Does throttle trigger move back to idle position when released?
5 Suggested Answers
  • 242 Answers
SOURCE: my leaf blower will run for about 10 minutes then
the head gasket has gone and leaking pressure to the cylinder
Posted on Dec 28, 2009
  • 204 Answers
SOURCE: homelite gas leaf blower losing power
There might be a small screen in the exhaust (it's a spark arrestor) that gets plugged with carbon. Will cause loss of power and eventually the machine will not run. You can just take the screen out and it will run better. Check the exhaust ports (look into the cylinder area after you take off the muffler) and see if it/they are plugged. If so, use only plastic or wooden items to clear the carbon out. Be careful not to get any in the cylinder. If you do, pull the starter rope several times to blow out the carbon.
Otherwise, some fuel line cleaner would be a good try to assist in the problem.
Posted on Dec 29, 2009
SOURCE: loss of power leaf blower - gas
Had the similar problem- start with removing the exhaust intake plate 1st--- clogs with super fine dust initially then larger particles... Mine was completely clogged- cleaned er' out now she blows like the wind!
Posted on Jun 11, 2011
emissionwiz
  • 84027 Answers
SOURCE: My Hitachi leaf blower was smoking after short term use
The engine gets hot, and the smell is likely not anything to worry about.
Posted on Oct 06, 2016
Oct 06, 2016 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
Hitachi rb24eap blower won't stay running
Check your air filter is not clogged. Clean or replace as necessary.
It is a grey sponge ring that is located behind the cover plate near the priming bulb.
May 27, 2014 | Hitachi RB24EAP - 23.9cc 2 Stroke Gas...
It wont start
After heavy use, to restart you must prime the bulb as usual, NOT use the choke (only for cold).
Apr 23, 2014 | Hitachi RB24EAP - 23.9cc 2 Stroke Gas...
Oil ratio
I use one of those small 2.6 oz oil containers in a gallon (128 oz) to give a 50:1 mix. If you want more oil in your mix add another container - but it will be more expensive and waste oil.
Apr 23, 2013 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
Hitachi RB24EAP engine start but no blow
Check the impeller (on the side opposite the pull starter) to see if it is locked to the drive shaft (in the center of the impeller). The shaft could be spinning but, if the impeller is loose on the shaft, it can't spin fast enough to force as much air through the nozzle as it should.
Oct 29, 2012 | Hitachi RB24EAP 23.9cc 2 Stroke 170 MPH...
Whats the best premix gas to use on a Husquarna 125B hand held Blower
The best mix to use is what's recommended in the manual but in most cases blowers use a 50:1 mix. The difference from 40:1 to 50:1 is negligible but you have to use what the motor is built for. Too much oil causes a loss of power because the gas won't burn efficiently. Too little oil and you risk damaging your piston or cylinder.
Feb 22, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Homelite gas leaf blower losing power
Dec 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
44 people viewed this question
Top Hitachi Garden Experts
Marvin
Marvin
John Jacobs
Karl H
Are you a Hitachi Garden Expert? Answer questions, earn points and help others
