SOURCE: idles but won`t accelerate
Change fuel filter.
fuel pump sounds fine.
Check for kinked or blocked lines.
If it has a fuel recovery cannister service it.
SOURCE: Tecumseh hm100 powermate generator won't stabilize
Check the air filter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: 02 yamaha vstar 1100, ran fine. started it the
Sounds like it may be drawing air around the intake somewhere. Let it idle and spray around carefully with wd-40 until it speeds up. This will reveal the leak.
SOURCE: Coleman Powermate Pro-Gen 5000, not been use in
remove bowl from the carb . clean it out ,and check for free fuel flow
SOURCE: have a coleman powermate 5000. Won't start. Laid
Cleaning the carb bowl is not enough make sure you pull out the main jet and clean it out real good. If it starts with starting fluid then it is definitely a fuel problem.
