Televison & Video Logo
Where can I buy a replacement screen for a Luxor 50 inch tv.
5 Related Answers
Anonymous
  • 78 Answers
  • Posted on Apr 07, 2008
SOURCE: Cracked Screen
Dell doesn't release schematics, unfortunately. Here's the closest I could find:
http://eserviceinfo.com/downloadsm/26785/Dell_W2600%20lcd%20tv.html
Anonymous
  • Posted on Oct 24, 2008
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Anonymous
  • 5138 Answers
  • Posted on Jun 03, 2010
SOURCE: my screen broke how do I replace it?
You will need to remove the bottom panel then screws holding it on, screen should slide up and out.
Chi Chu
  • 8457 Answers
  • Posted on Oct 29, 2011
SOURCE: best plasma TV HDMI
None.All Plasma tvs designs are alway have high heat output and consume alot more A/C power energy than any other tvs designs out there.Tvs like CRT-tube tvs,DLP tvs -Projection tubes and projection lamps tvs,LCD-flourescent tubes tvs as Liquid crystal display screen tvs.All these tvs designs are all good tvs designs to buy but the pictures display and screen lighting and the sharpness of the pictures never have and able to compare high enough qualities as a display picture on the screen output to a Plasma screen tvs,until now LED-tvs are LCD and LED screen display combine to make it better and brighter technologies and now are good enough to compare to a Plasma screen panel tv.So buy a LED tv will get less heat output and comsume less A/C power energy too and it is good enough pictures qualities too.To compare too as a plasma screen panel tvs output.
Anonymous
  • 195 Answers
  • Posted on Jan 10, 2012
SOURCE: Luxor 42 inch lcd tv stanby light flashing and tv
Good day!!!!
Kindly,count the blinks of your TV because some TV have error code by means of how many blinks..
thank you
How do I find Bluetooth off on my Luxor 55 inch TV
To find the Bluetooth setting on your Luxor 55 inch TV, press the "Menu" button on the remote control and select the "Settings" menu. From there, select the "Network" option and then select "Bluetooth". This will display the Bluetooth setting which can be toggled to "On" or "Off".
Luxor 43 inch hd smart tv has cut out twice whilst watching, managed to turn back on after 5 days, now been out for another 4 days, any help appreciated
The power cable faulty it seems to be a common problem in Luxor TVs if confident unscrew tha back panel the cable is on right hand side of the TV three pinned connection . Release the connector and replace. Or get s TV engineer . He'll repair ÂŁ10 or ÂŁ20 . I had same problem six months ago after replacing cable the TV works perfectly
I HAVE HAD MY LUXOR 52 INCH FLAT SCREEN TV ,BOUGHT FROM ASDA APROX 5 YRS AGO,,, IT HAS NOW STOPPED WORKING,,, THERE IS SOUND BUT NO PICTURE
Did you shine a flashlight behind the screen to see if the image is present, if so the backlight is burned out.
I have a Luxor 50" smart TV and it has lines going right down the middle off TV what's wrong with it
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Luxor LUX0150001B/01 50 inch LED Smart TV
What is the problem you faces with this TV? Provide more details; please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
Luxor tv turning off and on intermittently
Bad solder joints or bad capacitors in the power supply
Top Luxor Televison & Video Experts
Paul Bade
NOEL
NOEL
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
