SOURCE: shark professional model 505.
It sounds like the themostat inside the unit is broken. The only solution to fix the unit is to send it to the manufacturer for repair.
I'm unsure of the cost for the repair but it might be cheaper if the unit is older to throw it away and buy a new steamer.
SOURCE: where can I buy vacuum bags for my Bosch canister model BSG71 UC
Check out Ebay.com
or
http://cgi.ebay.com/GENUINE-BOSCH-TYPE-G-VACUUM-BAGS_W0QQitemZ190296223025QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190296223025&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
SOURCE: vacuum gets hot loses suction and turns off
You need to replace your silencing filter on the inside. I recommend calling Health Mor at 800-344-1840 and having their Tech. walk you through replacing that filter. It should have been replaced at about 2 years. It catches the carbon off the motor, but if dust is getting through it can clog it and cause your motor to overheat.
Good luck,
FQ Master
888-637-4692 in Iowa
Your Filter Queen Authorized Service & Supplies
SOURCE: It won't work. I
we need to know what type of machine we are talking about....Make and Model?
SOURCE: the spinning brushes mechanism won't spin.
With the machine switched off, press the re-set switch on the side of the head, making sure you push the button in as far as you can. When you switch the machine back on and lower it into the vacuuming position, the brush bar should start turning. --------The brushes don't spin if the unit is placed upright. First off check that you haven't pressed the button that turns the brush on and off.-- But if that is turned ON.Then the other possibility can be clogged brush with dirt. take a look at the brush bar to see how much hair and debris is caught in there. If there is very little then you probably don't have much to worry about and you can press the brush reset bar on the side of the vacuums head and your problem with they Dyson brush not turning can be fixed. Also check the be belt and the motor.If belt is got loose, then motor will spin but brush will not spin, due to loose or worn out belt.If belt is intact, but motor is not spinning, then its weak motor issue.If motor is the issue, then to replace and repair the motor.Please click the link below:---- http://dysonmedic.co.uk/dyson-dc24-brush-bar-motor/ ------------- The operating instruction for dc-24 and dc-25 are near to same.So if you require disassembly instructions.Please click this link below and see the video.This will help, for disassembly:--- http://www.videojug.com/film/loss-of-suction-dyson-dc25 ---------------- This should help, thanks.Helpmech.
