SOURCE: Color rainbow in picture
Your problem sounds like someone got a magnet too close to the CRT. This can be removed with a degauss coil (which you probably do not have) or it will eventually go away if your built in degauss circuit is working. Everytime you turn on the set the circuit degausses the crt so colors can be displayed properly. If the circuit is not working you will need to have a tech repair it.
SOURCE: Rainbow picture
The tube needs to be degausse you had maybe placed speakers beside the tv causing it to magnetize have a tech look at it to remedy the problem.good luck.
SOURCE: No Picture
I have the same problem was working fine and less than 2 months bam red screen green lines top to bottom no image on any input just volume works....Now i will be a victim of there horrible warranty service
SOURCE: pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubichi HD 1080 65" three colors like rainbows across screen
convergence problem...very common
