There could be several reasons why a cassette does not play when inserted into a system, and the power light blinks within 5 seconds. Here are some possible causes and solutions:
- Dirty or damaged cassette: The cassette tape itself may be dirty or damaged, preventing it from playing properly. Try cleaning the tape head and the cassette tape itself with a soft, dry cloth or a cassette cleaner. If the cassette is damaged, try playing a different cassette to see if the issue persists.
- Faulty cassette player: The cassette player itself may be faulty. Try inserting a different cassette to see if the issue persists. If other cassettes also do not play, then the cassette player may need to be repaired or replaced.
- Loose connections: Check that all the cables and connections between the cassette player and the amplifier or speakers are properly connected and not loose. If any connections are loose, tighten them and try playing the cassette again.
- Low batteries: If the cassette player is battery-powered, check that the batteries are fully charged or replace them with new ones. Low batteries can cause the power light to blink and prevent the cassette from playing properly.
If none of the above solutions work, then there may be a more serious problem with the cassette player, and it may need to be inspected and repaired by a professional technician.
