Question about Nikon Cameras
When I powered my Nikon d3100, it displays, This memory card cannot be used. Card maybe damaged. Insert another card. I removed the card, the message is keep showing as I powered it. N.B. no card inside.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Some of the pins at the memory reader are damaged. Or the PCB is faulty. Both scenaries need to go to a repair center.
Posted on Feb 28, 2019
Habubnik
  • 114 Answers
SOURCE: "Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Posted on Aug 29, 2005
Habubnik
  • 114 Answers
SOURCE: "Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Nitrotrike
  • 589 Answers
There is a little slide switch on the side of the memory card. Good luck!
Posted on Jan 08, 2008
SOURCE: "Memory card cannot be read"
My camera used to do the same thing--once I got the pictures off my card, I left it in the card reader, right clicked on removable media (my computer + removable storage) chose to "format" and formatted it on my computer. It seems to have fixed the problem, and my camera now reads it fine. I tried to format it on the camera before, but it didnt work.
Posted on Jun 02, 2008
SOURCE: Why can't you use 8GB memory card in Z710
I have a kodak z710 camera with a 2 gig card in it. I was wanting to get a 4 gig sdhc and i wasn't sure if the HC would work with this camera. HC stands for high capacity which means it allows the camera to load files on to the card faster. this may be the problem the kodak may not be HC compatable. but as i have said i have a 2 gig and it works fine with that. and i have a friend that has a 4 gig in thiers but once again i don't think it is HC so i would exchange the card if you can for just a regular SD/MMC card or SD card
Posted on Jan 21, 2010
My nikon d3100 takes a long time to process my sd card card and after that it displays a "card damaged" error. So I decided to buy a new sd card, but still gets the same error message. I got it checked at...
If a pin got damaged, then a trip back to a Nikon repair center is the only way to properly repair it. It may be still under warranty if it's less than 3 years old.
May 09, 2017 | Nikon D3100 Digital Camera
Import pictures Nikon D3100 get access denied
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Jul 17, 2013 | Nikon D3100 Digital Camera
I am unable to trasfer edited photos from my Nikon D3100 camera to computer
Remove the SD memory card from the camera and insert the SD memory into an USB memory card reader. Plug the memory card reader into the USB port of your computer, the computer will see this as an external storage device, you can then open the image folder and copy the photos from this folder to your computer.
Apr 11, 2012 | Nikon D3100 Digital Camera
Nikon d3100 showing no sd card inserted message even after inserting it..please help
The only thing I can think of remove the SD Card, start camera, and go into the menu, check to make sure there are no pictures on the internal memory, if there are! erase them and restart camera and power off, re-install card and hopefully you are good to go. If no change! have the camera shop run a quick check.
Mar 24, 2012 | Nikon D3100 Digital Camera
I left my nikon D3100 outside with the tripod and i forgot to get it,then suddenly it got wet from the rain,what will i do?
Remove the battery imediately, the memory card and the lens. Place the camera body, lens and memory card in a warm dry and place for several days to dry out completely.
When the camers is dry, insert the battery, lens and memory card, turn on the camers and set the date and time.
If the camers does not work charge the battery and try again.
If it still does not work then you need to send it to the Nikon service centre for repair.
Jan 15, 2012 | Nikon D3100 Digital Camera
My nikon D3100 got wet from rain...what will i do?
I just got my Nikon D3100 and it wont turn on..why?? i didnt buy a memory card yet..doest it need memory card to turn on??
The battery ships in an uncharged state. Slip the battery into the charger until the it indicates it is fully charged. Install into the camera. The camera should power up without an SD/SDHC/SDXC type memory card installed - and should flash [-E-] in the viewfinder alerting you to the fact that no memory card is inserted.
Sep 06, 2011 | Nikon D3100 Digital Camera
When I set my Nikon D3100 on and it is in auto mode, in the screen comes message " Error. Push the trigger again". And when I push it appears again and again. I Can't take any pictures at the...
hiyou first distinguish what it cause. I suggest separate body and lens. Please enable without memory card.( remove memory card), Set to Bulb speed on Mode. Press hold and see front of camera, you should see mirror up and shutter curtain fully open inside ccd image sensor surface. Release shutter button. See what error message come out.
Jun 03, 2011 | Nikon D3100 Digital Camera
I have a new D3100. I took pictures, then stuck the memory care in my hpC3150 card reader and the orange exclamation point lit up on the hp. I put the memory card back in the Nikon and it said, Memory...
I believe that the memory card was not formatted to the camera before using so, the pictures were corrupted and unable to read in either the computer or back in the camera. What you need to do is make sure the memory card is unlocked here is a diagram
Diagram
Make sure the card is unlocked then you need to format the card.
Jan 15, 2011 | Nikon D3100 Digital Camera
Cameras Logo
37 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
