Question about Polaroid Televison & Video
My Polaroid flat screen tv will turn off by itself. It will also automatically change to the tv option when I have it on Rear or HDMI. Please help.
Check in set up for power options see if program set
SOURCE:
walesarumi
  • 6993 Answers
SOURCE: My philips flat screen 42PF55 tv keeps turning itself off. The gr
This issue is related to a power problem in as much as the TV turns off on it's own.
The problem is consistent with overheating on the power supply board of the TV. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby making it to misbehave.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board from www/shopjimmy.com to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't have the ability to read the fault, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Nov 12, 2011
SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341, 11498, 11523, 11991, 11992
Posted on Dec 10, 2007
SOURCE: POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Posted on Oct 12, 2008
  • 2337 Answers
SOURCE: Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Dec 06, 2008
SOURCE: 42 IN CH POLAROID HDMI BLACK SCREEN
i had the same problem. i opened the panel in the back of the tv (3 screws) and opened the aluminum panel (3 screws). there's a red led light located at the bottom left corner of the top board. to the right of the led light, you will find this thing with 4 switches. i turned the two bottom switches "burn" and "epmw" to on. so far tv have been working.
Posted on Aug 22, 2009
What shall i do if my pc is stromsparmodous?
"That means power saving mode - Go into Control Panel>Power Options and check (and if necessary change) the power settings - how long before the monitor shuts off etc.
Another check may be to go to the NVidia control panel (R click on desktop and it should show in the drop down menu). go to 3D settings > manage 3D settings and in Global tab click Restore button - this will restore the program's default settings for how the card manages its 3D settings."
Nov 08, 2015 | ASUS Computers & Internet
When i turn on TV,have to exit the screen that pops up, then I have to go to the input and scroll all the way from TV to HDMI, can't I turn on TV will just go to the HDMI input
whatever it is that is plugged into your hdmi port will take over the tv ( sky dvd etc ) try turning the device off,turn your tv on,turn the device on. your tv should switch over to hdmi by itself and remember to ? hope this helps
Apr 21, 2015 | Televison & Video
Toshiba Satellite A105 hangs when charger is plugged
Toshiba Satellite laptops come with a unique power management software program that regulates the power consumption of your laptop. While this program is often helpful in extending laptop battery time, the program is also known to cause some operational difficulties when software conflicts occur. At some point you may want to change your power options, or remove the program.
Click "Start" and then "Control Panel." Locate the "Toshiba Power Manager" program among the Control Panel icons. Note that this differs from the familiar Windows "Power Options" icon. Open the Power Manager application. If you want to merely modify the current settings, the Power Manager gives you many options to choose from. For maximum battery life, consider setting the Power Manager to put the laptop into various states of "sleep" after so many minutes of inactivity. Select the menu items offered to achieve power savings for the monitor or hard drive, or both. Click "Save Settings" and exit the program. Remove the Power Manager if your laptop is prone to "freezing" or seems to have difficulty "waking up" from a Sleep or Hibernation mode. Go to "Start" and "Control Panel" and choose "Add Remove Programs." Navigate to the "Toshiba Power Saver" listing. Click "Remove." When Windows is done scrubbing the program from the system, click "OK" and exit Control Panel. Reboot. The Windows on-board power management program will now take precedence over this function.
Feb 14, 2013 | Toshiba Satellite A105 Notebook
If i leave computer on without anyone using it . computer goes to black/dark screen , can't perform any functions. also computer crashes at times during use.
You need to check your power settings. It is being set to go to turn of the drivers after a certain amount of time.
Control Panel\Hardware and Sound\Power Options Then change the power options so it does not shut off the hard drive.
Mar 06, 2011 | Gateway DX4300-03 Desktop PC
I have a polaroid lcd tv 32 inch. i turned it on today and there was no picture but all the sound was there even with a dvd playing there is no picture only sound i have checked all leads and everything...
Well it very well could be the three color tubes, or power board the problem. BUT before you try that check your HDMI cable. HDMI cables have to be 100% in to fully work sometimes if out just a bit they will produce this issue where you have no picture but sound.
Or try a new HDMI cable, if you don't have HDMI and it's doing it on multiple ports including RCA, RF, HD Component then it's a problem with the tv itself and you'll need to call a repairman.
Mar 02, 2011 | Polaroid 3211TLXB 32 in. LCD Television
The tv was turned off with the remote 'set' button. Now, none of the power buttons including the one on the tv itself work to turn the tv on. Perplexed.
my remote control will not work after changing the battery on POLAROID ORIGINAL LCD FLU-2632 TV REMOTE CONTROL please help
Dec 12, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
IBM Z60T randomly turns off, both on battery and AC power. Have checked the power settings and are set at default, have tried other settings as well
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc if issue persist:
Control panel---> Programs and features ---> highlight Lenovo power management\Energy management---> left-click "uninstall" ,restart pc
Mar 06, 2010 | IBM ThinkPad Z60T Notebook
Polaroid FLU-2632 LCD TV full HD 2 HDMI problem
You could try pressing the source button on the remote to see if that brings it up.
Also the TV may have got itself in a muddle. There will be a way to reset it to factory setting. If you can get into the TV's setup menu there ought to be an option buried somewhere to do that.
Apr 28, 2017 | Polaroid FLM-2632 Television
Unti wont keep set temp, it actually keeps changing the temp. itself..either 60 or 90..like it has a mind of its own. Is there a reset option or is it just done
These temperatures are generally associated
with default (factory) values. Programmable
thermostats have batteries/capacitors to retain
program memory during power outages.
Check batteries/power supply. Switch fan on at t-stat to verify control voltage. Program
t-stat and restore operation.
Please also check low voltage connections
for tightness (power off).
Aug 06, 2009 | Heating & Cooling
Jun 12, 2009 | Polaroid FLM-2632 Television
Televison & Video Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
