20 Most Recent Keurig K145 OfficePRO Brewing System ...
Mar 2, 2014
20 Most Recent Keurig B3000SE Large Office Brewing Questions ...
Sep 19, 2012
20 Most Recent Keurig B40 Coffee Maker Questions & Answers
Sep 19, 2012
20 Most Recent Keurig Milk Frother Questions & Answers
Aug 14, 2012
More results from www.fixya.com
SOURCE: what is the format for the Keurig coffee serial
I had the same problem. I tried the following format and it finally worked:
xx.xxxx.xxxxxxx
Apparently you need to put the decimals in. Good luck.
SOURCE: keurig coffee maker makes loud noise single cup
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
SOURCE: We have had our Keurig
Sorry to read about your problem, I hope this helps you out.
It sounds like you unit has a major malfunction. and they do break
Keurig does not make repair's or carries replacement parts for their units. you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Testimonial: "Thanks for the immediate response. I will contact Customer Service at the telephone no. you gave me. Hope I get a good response from them. "
SOURCE: All LED lights flashing and the brewer does not work
I had the same problem. They told me it had to be "reinitialized" To do so, press the auto-off, small, and large cup buttons simultaneously then release. All lights should go off. Unplug, replug, then press power and it should work again.
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
How
heatman101
heatman101
How
heatman101
How
heatman101
heatman101
heatman101
heatman101
