Question about Canon Office Equipment & Supplies
Canon Image Formula Dr-2020U We scan a portion of a file, assign a name & close. We scan more of the file the program will not allow the original file to take the scan.It gives a new file name/folder
SOURCE:
mohanchennai
  • 490 Answers
SOURCE: Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Posted on Jun 23, 2008
  • 3 Answers
SOURCE: CANON DR 7580 SCANNER : SCANNED IMAGE HAS A LIGHT
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
Posted on Jun 09, 2009
  • 17 Answers
SOURCE: Link Scanned Image - Error Message on Canon CanoScan 500F
"Link Scanned images to..." refers to the programme you want to open the file. Navigate to the .exe of your preferred viewer
Posted on Jun 11, 2009
SOURCE: I have a canon DR-9080c that gives me a PAFCV2.DLL load error
I have resolved this in the past and a new user just brought it up again.
The pafcv2.dll in Captureperfect 2 does not seem to work. If you install CapturePerfect 3 and copy the pafcv2.dll into captureperfect (c:\program files\canon electronics\captureperfect2 or whatever install path you used), you will find that you can now scan into PDF, even in batches!
Posted on Jul 08, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-3020 Scanner with Windows XP Pro
Download Dr 3020 drivers for XP from http://software.canon-europe.com/products/0000666.asp
Try connecting the scanner to a diff computer and check if it is okay. Also pls ensure SCSI termination is okay.
S. Mohan
Posted on Jul 11, 2009
How to store documents from computer to ricoh 3035?
When the machine is printing a
document stored using the copier
function, wait until printing has
finished before you store a document
in the Document Server.
A Press the {Document Server} key.
B Press [Scan Original].
C Enter a file name, user name, or
password if necessary.
Note
- If you do not enter a file name,
one is automatically assigned.
Reference
p.41 "To register or change the
user name"
p.41 "To change the file name"
p.42 "To set or change the password"
D Place originals either on the exposure
glass or in the ADF.
Reference
For information about types of
originals and how to place
them, see Copy Reference.
E Make any required settings.
Reference
For details, see Copy Reference.
F Press the {Start} key.
The document is stored in the Document
Server.
Note
- To stop scanning, press the
{Clear/Stop} key. To restart a
paused scanning job, press [Continue]
in the confirmation display.
To delete saved images
and cancel the job, press [Stop].
-When a password is set, appears
on the left side of the file
name.
- After scanning, stored documents
appear on the Select Files
to Print display. If this display
does not appear, press [Scanning
Finished].
- When placing an original on the
exposure glass, press [Scanning
Finished] after all the originals
have been scanned
To register or change the user name
A Press [Scan Original].
The Scan Original display appears.
B Press [User Name].
If user names are already registered,
the Change User Name display
appears. To use an
unregistered user name, press
[Non-programmed Name].
When no user name are registered
in the Address Book, the User
(Destination) Name entry display
appears.
When using a registered user
name in the Address Book
ASelect a registered user name
from the list, and then press
[OK].
To change your user name to an
unregistered user name, proceed
to the next step.
Reference
p.76 "Registering a New
User Code"
When using an unregistered user
ATo enter an unregistered user
name, press [Non-programmed
Name].
BEnter a new user name, and
then press [OK].
Reference
p.161 "Entering Text"
When no user name has been
registered in the Address Book
AEnter a new user name, and
then press [OK].
Reference
B Press [File Name].
The Change File Name display appears.
C Press [Delete All] to delete the old
file name.
Note
- You can also use [Backspace] to
delete unnecessary characters.
D Enter a new file name, and then
press [OK].
Note
- Up to 20 characters can be entered
as a file name. Note that
only 15 characters of each file
name appear in the document
list.
Reference
B Press [Password].
C Enter a password using the
number keys (four-to eight-digits),
and then press the {#} key.
D Reenter the password (four-to
eight-digits) for verification, and
E Press [OK].
May 22, 2014 | Ricoh Aficio 3045, 3035 Kit
1) How to Detect Automatic PageSize (eg. Remove Black Color of Scanned Image at the end of the Page.) 2) Compression Using JPEG Compression. 3) Set Name Rule and File Format How to set all...
I presume that you are using CapturePerfect ver 3 as scanning software. Please select "Auto-detection" under page size and also 'deskew' using both Roller & Image' under filters. Under file format, you need to select JPEG. Naming convention is available, however I'd suggest that you choose the name which is convenient to you. Multipage is NOT available with JPG format.
S. Mohan, Chennai, India
Jan 11, 2011 | Canon DR-9080C Path-Through Scanner
When scanning, there are lines on the image I have scanned.
Use a blank sheet of paper (as white and clean as possible). Put it in the scanner landscape ( you will need to cut off about 1/2 inch of the paper to make it fit. The run the DR-3080CII Shading tool (DR3KUserSh.exe) C:\Program Files (x86)\Canon Electronics\DR-3080CII\DR3KUserSh.exe
May 19, 2010 | Canon DR 3080C Path-Through Scanner
My scanning files are to big
Since there's not much information, I'm going to have to make a lot of assumptions with this solution.
The basic issue you have is not the scanning, it's the scaling after the scanning. Since you do not indicate what software you are using to scan the image, I can't be certain without knowing what you're using, but most of these scanning packages allow you to 'resize' or 'scale' the image. How much to scale depends on how large the original is, and how small you need the final version, so some experimentation may be in order. As an example, with my scanner, I typically resize to about 50% of the original.
If you don't have that option, most graphics programs allow this fairly easily (you simply save, then open the scanned image in the image editor and perform the scaling there). Or, some programs even let you resize without opening the file, such as Microsoft's free Image Resizer tool (http://download.microsoft.com/download/whistler/Install/2/WXP/EN-US/ImageResizerPowertoySetup.exe) which allows resizing by right clicking on the file name.
Jan 26, 2009 | HP Scanjet 5590 Flatbed Scanner
How do i save the image once i have scanned it on CanoScan LiDe25
it may be that you have to close the program - i had a similar problem at first but found it stores them all until the program is closed, then a window pops up with little thumbnails of all my scans (meaning you can continue to scan new images without apparently having saved them to the harddrive). This new window allows the user to untic whichever scans are not desired... there is a svae button at the bottom, and the svaed scans will be found in the Pictures folder in a sub-a folder with that days date as the name.
Jan 26, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Failed to open a driver
OK. Here is what you do. (I just did this on an Intel Mac running OX10.5.6)
First go to the cannon site and get the program (File name: deldrvosx1510en.dmg) to uninstall the drivers for your scanner. Also, delete copies of the scan toolbox that you may have installed in your application folder.
Then go back to the canon site for the LiDE 25 and install the drivers (file name: lide25osx11030en.dmg.) This part is very important, in the middle of the install a dialog will popup asking if it is OK to run something like deldvr, DO NOT ALLOW IT TO RUN, HIT CANCEL.
reboot.
Install the canon toolbox software (it should be version 4.9.x not 5.0). File name is : cstbosx4934ej4.dmg
You should now be good to go.
What a %^#%$#-up process on Canons part.
Dec 24, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
SCANER,PRINTER,COPYER
Saving a scanned image on the computer
1 Load an original document facedown on the scanner glass.
2 Close the top cover.
3 From the desktop, double-click the Lexmark Imaging Studio icon.
4 Click Scan.
5 Select the Photo, Several Photos, or Document option.
6 Click Start.
7 From the Save or Edit screen menu bar, click Save.
8 To save to another folder, click Browse, and select a folder. Click OK.
9 To rename the file, enter the name in the File Name area. To assign the name as a prefix to all of your photos,
select the “Start all photos with File Name” check box.
10 To save the photo as another file type, select the file type from the File Type drop-down list.
11 To select a date for the photo, click the drop-down list, and select a date from the calendar.
12 Click Save.
Jan 22, 2008 | Lexmark X2500 All-In-One Printer
19 people viewed this question
Clive
Clive
old marine
old marine
