SOURCE: Toilet won't flush
Thetford Model Cass C2 L TC WHI - Toilet won't flush. There is power to the switch and flasher. Any ideas?
SOURCE: Toilet was not flushing all the way unless I held
Adjust the chain (or strap) to the flapper. It sounds like you need to give it a little slack.
Testimonial: "You were exactly right. This site is great!"
SOURCE: Kohler 1-piece flush valve seal replacement.
That is a tricky one. Tighten the tabs, twist into place, then tighten a bit more. They are a pain in the a$$, but with patience you will get it done. Good luck
SOURCE: Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
SOURCE: Flush button won't work. 12 yr old Duravit Toilet
The push button siphon assembly is worn out. Just replace it entirely.
