Question about The Office Equipment & Supplies
XP 430. Paper feeds without print. No jam indicator comes on.
I have tried wired and Wifi. The printer is working and connected either way, and the ink levels are high. The first time I tried to print, only the color parts of the document printed. When I switched to black and white, there is no print. Any suggestions please?
SOURCE: Paper Feed Problem
I had this same problem - you could hear the printer "trying" to pick the paper up.  After a few cycles it would stop  and pop up the media jam error.  I noticed this would never happen when the try was half to completely full - only when the stack was low.  I pulled put the paper, inserted a feather duster, applied some elbow grease (or wrist in this case) - problem solved.
Posted on Oct 11, 2007
SOURCE: Black stopped printing out. Dell 922 all-in-one ink jet.
HI thanks for that and i will try it.
Posted on Jan 15, 2008
  • 27 Answers
SOURCE: HP Photosmart 8450 Ink Level Indicator
replace the ink cartridges
Posted on May 31, 2008
  • 630 Answers
SOURCE: wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Posted on Aug 22, 2009
SOURCE: dell 926 photo printer will not print black ink.
Nope, not the cartridge...swapped out known good cartridge from our other Dell 926, still the same problem...printer will not print black...both carts work fine in other Dell 926
Posted on Apr 01, 2010
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
I have changed out my black ink cartridge and now it says Attention: Print head loose, missing or not installed correctly.
Had exactly the same issue - working fine until ink cartridge changed (kodak for kodak - not a copy). Then can only get 'print head error message'.
Multiple attempts to remove and re-install, power on/off etc. but can't shift the error message. New print head more expensive than a new printer!
May 06, 2015 | Kodak Office Hero 6.1 All-in-One WiFi...
My dell printer 5100cn , print quality very light, replaced inks drum and still having problem with black
laser printers have a high freq high voltage wire that puts ions on the paper as it passes ,
have you cleaned this wire . it attracts dirt an inks like the paper it treats.
there is a wire cleaning tool in the machine usually.
Jan 04, 2015 | Dell 5100cn Laser Printer
Paper jams on epsonXP605 expression printer
Printing photos from the back feed? Using special photo paper? Try cleaning the paper rollers that feed the paper. They get slick.
Sep 03, 2014 | Epson Expression XP- 605 Inkjet...
How to reset hp d1663 ink levels
hp D1663 is my printer, problem is does not print, After Installing drive for first times it works, ink level is fine.
But after 3rd or 4th printing it does not print at the same time ink level problem is shown in the display popup....so again uninstall print driver & same problem repeats...please help?
Jan 27, 2012 | Office Equipment & Supplies
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Cannot get my printer to print
Power cycle the printer
Try again
How is it connected?usb?wired ethernet?wireless?
check the connectivity coz it matters
what are you trying to print?
try printing from notepad if it prints i could be the software you are using like MS Office or MS Word
if it totally not printing from pc to printer
check the printer as standalone if it is printing fine
if not check the ink levels you might need to replace inks
For detailed troubleshooting steps check below link this might help you a lot
Print issues
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=23336&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3390949
Slow / No response from printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=38033&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3390949
Hope I help you a bit
Mar 27, 2011 | HP DeskJet F4280 All In One Printer InkJet
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
PAPER NOT GETTING LOADED
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-12
Aug 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
16 people viewed this question
Top The Office Equipment & Supplies Experts
Scott Yeoman
vince
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
