I have 43 inch Sinotec tv but I don't have a remote, the tv shows "please select an OSD Language". Please help I'm stuck and my tv doesn't have buttons for control
    Habit-Forming:
    Scholar:
  • 47 Answers
Most usually they will have small buttons on the side or rear. They are sometimes hard to see. It is best to pull it out and use a bright flash light to check for these. You should be able to buy a universal remote and follow the directions on how to program it. You may be able to select the DEFAULT settings and place the tv back to the program which came with it when it was new. I would say your best bet would be to get a new universal remote control. I hope this helps with your problem.
Posted on Feb 12, 2019
SOURCE:
MikeNJ1964
  • 398 Answers
SOURCE: Menu Language
According to Hitachi themselves, there is no such set with model number C29-F100. The closest one they have on file is the C29-F800. Perhaps your set is an over-seas set, originally sold in Japan? The original remote has a MENU button surrounded by 4 "arrow" buttons - arrow up, down, left and right. For the C29-F800, using the original remote, press the MENU button 4 times or the SETUP button once. There should be 4 choices on that page and the first one, the one on top, is LANGUAGE. Highlight the first one using the "arrow down" (also labeled P-) button and select the language ENGLISH using the left or right arrow buttons. Exit the menu by pressing MENU 3 more times or SETUP once. I believe I can download the owner's manual for the C29-F800 and send it to you if you need it.
Posted on Aug 23, 2007
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
Posted on Feb 05, 2008
SOURCE: TV Stuck - Probably Thompson as says Black Diva
sevice mode remote code
Posted on Dec 31, 2008
  • 814 Answers
SOURCE: I can`t switch on my g-hanz TV
http://resources.jvc.com/Resources/00/00/94/YA059ien.pdf This is a link to a pdf copy of the owners manual for your model television. You can find all the setting and function controls listed in the manual. To reset the television to factory settings, you must unplug it from the a/c power source for about thirty minutes. This will reset the television to the factory settings. You can do the same thing with the remote control. Just remove the batteries and press the input button continuously for about 1 minute. This will drain all the power out of the microprocessor and reset the remote control to the factory settings. You can then use the owners manuals to reset the television and remote functions.On turning on the television the interactive plug in menu will appear. From here you can set the language you want to use for the television. All of this is explained in the owners manual.You will need a pdf reader and writer to read the owners manual and the writer to make a copy for your own use. I hope this information helps you with your problems with the remote control and television. Thank you for using FixYa and have a nice day!
Posted on Jun 20, 2009
Where can I get a universal remote control for Sinotec 39 inch HD flat screen tv
Hello, Ncedisa -
Since yours is a Sinotec television, I hope I am correct in guessing you reside in South Africa.
Note: Fixya.com receives questions from people worldwide. I am answering from the USA.
I suggest you contact Sinotec directly (Sinotec Customer Service) and ask your question:
http://www.sinoprima.co.za/get-in-touch/
Best wishes.
Jun 28, 2018 | Universal Remote Control Televison & Video
Sinotec tv no remote only Universal remote huayu HR-N98in usb can't get the AV menu help pleas???don't know what to do : :
With no universal remote control, you can select its inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
If you wish to get further advice over phone; visit this absolutely free service https://www.6ya.com/
Dec 10, 2016 | Universal Televison & Video
Hi I lost my sinotec led tv 40" remote and I can't select OK on TV buttons to select osd language without remote
Its not possible without remote
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Televison & Video
How do I select an OSD language for sinotec 3d led tv ,I lost a remote control?
Without a remote control; you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 01, 2015 | Televison & Video
I need remote code for sinotec 42 inch full hd tv
If you have a new universal remote, you can use its code search feature to find a code for your Sinotec TV. If you search through all codes stored in the remote with no result, you may have to try another universal remote. All programmable remotes do not store all possible codes in their library.
Dec 12, 2014 | Televison & Video
My toshiba tv is stuck on initial setup menu, language selection. original remote is not working
Hi,, today i got the solution for the problem 'Tv Stuck On Language Screen"
I have Skyworth Lcd and it was stuck on Language screen 4 days back, i've tried every sigle App and Different Universal Remotes and buttons on Tv but nothing was working except a single App named "SURE UNIVERSAL REMOTE FOR TV"
i suggest if someone face this Language screen stucking problem and no buttons and remotes are working then you should download this App on your Cell phone and select your tv and you'll surely be able to restore your Tv.
Feb 10, 2013 | Toshiba 40RV525U 40 in. LCD TV
How do you remove the self check on a panasonic viera 37 in lcd tv?
Hello:
This procedure will bring up the self test screen and reset the unit to factory settings for you.
First produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote control for more than 3 seconds.
Oct 10, 2011 | Panasonic Viera TC-37LZ85 LCD TV
Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Nov 04, 2008 | Philips 32PT5441/37 32" TV
Magnavox 26MD255V/17
Try unplugging the set for 2 minutes first then try operations again. If that doesn't fix it maybe one of the buttons on the TV is stuck or the remote control is sending erratic commands.
Apr 08, 2007 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
