Question about Xerox Office Equipment & Supplies
Can I use the fixing of Xerox WC 5855 for Xerox WC 5865? The two rollers of these to copier are different in Diameter
SOURCE: Xerox 416 Work Centre Pro Paper Jam
sorry i was having downtime with my cpu before now .
for your paper jam, check your copier manual for reomended paper grammmage prescribe by xerox.
entring tray jamming,use a damp towel to clean the picking rubber or roller inside the tray & use blower to blow dust out of the entrance sensor.
exit jamming, check the fuser unit of smooth runniing during machine warmup.check if there is any ink stuck on the rollers .then check the sepration fingers on the roller if there is any stuck spring.
but if your maching is jamming without any specific position,check your input & output voltage of your power pack for possible voltage drop. moreso you have to make sure that your machine is place on a level table.
thanks.
Posted on Sep 29, 2008
SOURCE: Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Posted on Oct 07, 2008
SOURCE: Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Posted on Apr 16, 2009
SOURCE: Is it ok to switch tire size from 225/55P17 to
Two items to consider when doing that swap...First, the smaller tires must turn faster to go the same speed/distance as the larger ones which will affect fuel consumption and alter speedometer reading. Second, your abs brake system reads wheel speed and having different turning rates may be interpreted as a partial skid which can cause problems. Best to stay with same size on front and rear.
Posted on Oct 26, 2009
SOURCE: difference in knock sensor for 1997 2.4 litre vs
You cant make it work, you need to get the correct sensor.
Posted on Feb 05, 2010
Mar 30, 2018 | Xerox Office Equipment & Supplies
Oct 27, 2010 | Xerox CopyCentre C123 Black and White...
Dec 04, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Dec 02, 2009 | Xerox Phaser 6360 Laser Printer
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
Sep 01, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Jun 30, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Apr 26, 2008 | Xerox DocuColor 12 Color Copier
Nov 07, 2007 | Xerox DOCUMATE 510 Flatbed Scanner
