Question about Watches
Charger red light lights up but not charging watch, completely dead
    Problem Solver:
  • 9 Answers
Check that the charge point on the watch doesn’t have any dirt of fluff in it as this will stop the watch charging correctly.
Posted on Feb 12, 2019
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
SOURCE: W850i red light prob
When it is red light of death, it either means the bootloader of the phone is faulty (after uploading dodgy firmware updates), or the battery is too empty to start-up, let alone display charging progress. In your case you need to leave the phone charging even with the red light flashing and it will be fine. Give it a few hours connected to the charger.
Posted on May 27, 2008
SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Posted on Nov 18, 2008
comax
  • 154 Answers
SOURCE: Skil charger & batteries won't charge
The only thing I suggest is taking your Skil driver to a Bosch service center (Skil is now owned by Bosch) and they will replace the charger under warranty if the driver is less than a yr old. If not those chargers are not that expensive. Either way you need a new charger because they are not repairable.
Posted on Jun 11, 2009
  • 103 Answers
SOURCE: I have an Elite Traveler Plus.
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
Posted on Dec 16, 2009
SOURCE: the red light does not come on when I charge the
I have bad news for you, most likely, you have a drop dead battery.
But there is good, it can be replaced, if not afraid of a screwdriver and soldering iron:)
If you disassemble the unit, you'll find the battery if you own a soldering iron it can be easily replaced by the same or even greater capacity.
Posted on May 14, 2010
My JBL CHARE wont charge it will only flash a red light
I assume you mean a JBL Charge. As for that specific model I am unfamiliar, however if when you try to charge electronics they will only flash a red light that's usually a battery or charger error signal. Most likely either a battery in the battery pack has gone bad, a contact has come loose or your charger has broken. Did you happen to drop it shortly before this error occurred? Also was the battery completely dead right before this happened? Sometimes I have noticed wireless devices will refuse to charge a battery if it is completely drained.
Dec 02, 2014 | JBL Audio Players & Recorders
What does wait to connect to battery mean?
It means the charger does not see any voltage from the wheelchair. If the batteries are very low or completely dead the charger cannot start charging. Each battery needs to have approximately 9 volts left in it.
Sep 25, 2014 | Health & Beauty
Instructions for Samsung galaxy s3 charger
It should show green light. Its nice phone and I have used this and never had any issue like this. You can also check at Samsung India site in support option. May be you can get some help from there.
Samsung Galaxy S3 Price India Buy 3 Smartphone Features Reviews Specs
Dec 27, 2012 | Samsung Galaxy S3 S III Spare Battery...
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
Sep 06, 2012 | Plantronics Explorer 210 Wireless...
The charger red light kept blinking while im trying to charge the batteries. after charge the battery overnight, the battery went dead after i took a few photos. does the problem lies in battery or...
Welcome to FixYa.
Red light indicates that the battery is charging. The light will goes off to inform you the charging is complete. Possible that the battery was alreay damaged since you left it charging overnight. Charging time is approximately 5 hours only.
I suggest that you have to replace your battery with a new one.
Feel free to send us your suggestion or comments if this solution was helpful.
Thank you for using FixYa.
Apr 11, 2011 | Olympus Stylus 790SW Digital Camera
Not charging . not nworking battery dead?
mcdevito75 here, If the battery is 2 years old, it could be un--able to accept a charge. Double check instalation into the charger, make sure charger itself is plugged into outlet. If so, visit a small watch repair shop in your area for battery change.
Jun 27, 2010 | Citizen Eco-Drive JR3080-51L Wrist Watch
End-of-life indicator for Victorinox Night Vision II watch - I seemed to remember that the watch battery can be monitored through the red LED that blinks every 10 secs. when it is OK, if the battery needs...
Not a malfunction - just a dead battery. See the manual:
http://www.victorinox.com/medias/sys_master/timepieces_manuals/8800396705822/NightVision_II_ENGLISH.pdf
May 12, 2010 | Watches
Garmin watch
If you haven't already done so, try replacing the battery.
You can remove the battery cover with a small coin, check the type (all batteries are marked) and buy a replacement.
Jan 16, 2010 | Watches
Watches Logo
22 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
