I can't turn my tecknicka tv from dvd to tv as I don't have remote
    Habit-Forming:
    New Friend:
  • 30 Answers
Use the command prompts on the TV. It takes a couple of minutes to adapt. Then rotate through the routine. You can overcome to adapt until a replacement is in your hands
Posted on Feb 13, 2019
  • Chaz Karchner
    Chaz Karchner Feb 13, 2019
  • Sheena Feb 13, 2019
    Thankyou I've done it finally...missing the soaps were driving me crazy lol
    New Friend:
  • 9 Answers
You can either get the model number off the back and contact the manufacturer to see if you can get a replacement or purchase a universal remote to see if that works.
Posted on Feb 12, 2019
  • Sheena Feb 12, 2019
    Thanks so much
SOURCE:
Flashing 3 colors red, green and blue to turn it off I had to unplug it. Trying to switching from TV to DVD. This have happened before. I don't have a remote but the service man reset it some how
Download the user manual to your TV. It will have all details about how to reset it to factory default. A factory default set should be done now. To download its user manual, click here.
Jun 21, 2012 | Sylvania LD320SSX LCD TV
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
I don't have a remote. How do I get it to play dvd
You need the TV Remote to put into that AV mode, if you don't have check ebay for one.
Dec 23, 2011 | RCA Televison & Video
I have and old emerson tv (ewt19s2) that i want to use a dvd player with. the remote isnt working. what can i do to the tv to make the right screen work?
HI JENN,
I ASSUME YOU DON'T HAVE A REMOTE FOR YOUR TV EITHER SO...
I WOULD EITHER PURCHASE AN INEXPENSIVE UNIVERSAL REMOTE COMPATIBLE TO THE DVD PLAYER AND EITHER USE PATCH CORDS, OR AN A/B SPLITTER, SO YOU CAN GO OUT THE DVD INTO THE TV...THE SAME AS YOU WOULD HOOK UP A VCR.
YOU DON'T NEED A REMOTE FOR EITHER, YOU CAN TURN BOTH ON AND OFF MANUALLY...
YOU ONLY NEED TO MAKE SURE THE TV IS SET TO THE SAME CHANNEL AS ON THE DVD PLAYER 3 OR 4.
HOPE THIS HELPS! I WOULD APPRECIATE A RATING FROM YOU.
KIND REGARDS!
MARTIE
Sep 08, 2011 | Televison & Video
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
My panasonic tv dvd vvcr combo remte rplacement i have tryed universals remotes but they don't work
Return the universal remote,if all ur tv universal codes of ur tv on the owner manual,don't work.Try website like Remotes.com to buy the tv original remote or very close capatible to it.Yes,it cost double even tripple the prices of any niversal remotes,but these remotes are 100% it will work with ur tv,because it the same or compatible as a orginal remote would.
May 31, 2011 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
Remote problem Hisense
I GOT A NEW HD WIDESCREEM POLAROID. DIRECTTV CONTROL PUTS ON POWER ON TV,CHANGES CHANNELS BUT DOES NOT CONTROL VOLUME NOR CONTROL DVD ANDVCR PLEASE HELP GODWIN
Jan 08, 2008 | One For All URC-4021 Remote Control
Zenith TV
have u tried using a universal remote and programming it for your tv? sometimes universal remotes can break a code that a common tv remote cant, hope this helps, just a suggestion!!!!
Dec 28, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
