Question about Cell Phones
How to connect my mobile Wifi - Cell Phones
    Sergeant:
  • 133 Answers
To connect you mobile to wifi make sure both the wifi locations in mobile and wifi are in working mode and after that search for available connection make sure you are in range of your wifi and after that select your wifi enter password if any and press connect now button for more info contact : http://bit.ly/2FreOnT
Posted on Feb 12, 2019
SOURCE:
Can you set up, AND use, CHROMECAST, with ONE mobile phone/tablet that has mobile data?
You are confusing yourself.
Mobile Data uses the internet direct from the mobile device.
WiFi uses public or private connection from phone to Router to Internet.
Mobile Hotspot or 'tethering', allows you to connect one device, through another to use data or wifi of the host device.
In your case, you want to connect Chromcast via your device using Mobile Data. Yes you can, see the link for explanation and videos.
can chromecast use mobile data Google Search
Jan 08, 2018 | Verizon Cell Phones
How do i get internet connections?
Richards, Smartphone How to connect to the internet, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Connect Your SmartPhone to Internet Only Using WiFi
How to access the internet on smartphone
How to Connect Your Android to Your PCs Internet Connection Over USB
Aug 09, 2016 | Nokia Lumia 630 8GB Unlocked GSM Windows...
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
Feb 26, 2015 | Nikon COOLPIX Cameras
I have no wifi so will i connect with wifi on my mobile
you are not required to have wifi at your home or anywhere else, there are wifi hotspots such as Mcdonalds and other places. If the data on her phone is turned on you can pick up the wifi on your phone which may cause you to have data charges on your bill. You should be able to turn your wifi off so that this does not happen you may also be able to turn off your data under your setting>cellular>cellular data and then you will not be able to connect to any data at all. Hope this helps
Feb 13, 2013 | Samsung Cell Phones
Cannot connect with wifi on mobile.
For wifi connection:
1. Make sure that you have a working modem router in your premise.2. Turn the modem/router on.3. Select settings icon from your mobile phone.4. Select Wireless Connection or WI-FI connection.5. Select options, then select connect.6. You will be asked for the WEP or WPA key. This is depending on what is the security option that you selected in the modem settings. (for modem settings you can contact your internet service provider or OEM for the modem)7. If you are aware of your pre shared key, just type it in the password option from the mobile screen.8. Once connected, you can use the wifi as your active connection access.
Jan 14, 2012 | Cell Phones
I have the Samsung Ch@t 335. When I try to connect to the wifi it will connect for about 5 minutes. Then you try again and it will say 'Failed to connect to network. Authentication failed.' If you...
I think your mobile has been very old or you use to connect your mobile to wifi a lot before,there could be some problem with your mobile software so once reinstall your mobile operating software
Aug 23, 2011 | Samsung Cht 335 Cell Phone
I have a laptop OS win7. I hav internet over LAN port. My laptop has wifi. How can i share my internet with laptop wifi. i hav a mobile which has wifi. My question is how can i share my internet through...
You can use your laptop to share the connection to your mobile through wifi. You need to have wireless router to share the connection to your mobile through wifi.
May 30, 2011 | Computers & Internet
I want connect a internet to my mobile by wifi the mobile asking the password
Hi. There's a security key to the wifi were you are connecting. You need to ask the owner of the wifi what's the security key. You need to input it before you can connect to the wifi
May 06, 2011 | Samsung Star GT-S5233 Cell Phone
I am trying to connect to my virgin mobile internet via the virgin mobile flash drive, the netbook isn't even picking up that I have the flash drive plugged into the computer.
If this is a Sylvania Netbook running Win CE 6 it is possible that the operating system simply doesn't have a driver for Virgin Mobile cellphone.
The only way I have been able to connect to the internet is via Wifi or a LAN cable plugged into the back. I doubt you will get any other method to work.
Please note the Wifi can be via a Wifi access point on your cellphone, a portable, mobile hotspot that connects via a USB modem or any other functional Wifi access point.
Tom M.
May 03, 2011 | Sylvania G-Netbook
My laptop has Wi FI My mobile also has wifi can
No. Laptop and Mobiles are passive WiFi receivers. You will need a WiFi router which when connected to internet will create a WiFi zone around it. You can no connect your laptop and mobile to this router.
Feb 26, 2009 | Dell Inspiron 1501 Notebook
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
