Bad heater element
I had the same error code and I found this very effective. (Saved me 100$) although I got this baby at a thrift shop. ?? unplug for atleast an hour (I did overnight) run a vinegar/water solution through on cleaning cycle and then brew 3 pot fulls of water and viola perfectly fine and also a very clean machine. ??
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: algae in Braun coffee maker float tube
Use a mix of 50% laundry bleach and 50% water.
Half fill the tank and let it soak for several hours.
Rinse tank and refill with fresh water only.
NEVER RUN BLEACH THROUGH THE MACHINE.
SOURCE: Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
SOURCE: our coffee maker is only brewing half of the
Run a 1/2 pot of vinegar through it 2-3 times (I reuse it) and then run water 1-2 times to get the vinegar smell out. This cleans the mineral deposits from your water that are clogging it.
SOURCE: my kitchenaid coffee maker gives
This problem occurs between 6 months and 1 year of these coffee pots. I have contacted customer service each time this occurs and have received a new coffee pot. Unfortunately, I am calling them again and again because the new coffee pots do not even last their warranty time and the ERR2 light again comes on and ruins my morning. I would not recommend this coffee pot. It is expensive and life time is not long at all. Customer service has been great but how many times do you have to return a coffee pot for Kitchenaid to get the hint that it needs to be fixed. Most consumers will get angry, throw it away and never buy the same one again. So, wake up Kitchenaid and smell the COFFEE!!!!!!!!!!!!!!!!!!!!!!!!! Fix this coffeepot. I am not the only one who has had this problem. Customer service @ 1-800-541-6390 Hope this helps. When they send you a new one they send you free shipping back for the old one and you use the box the new one came in.
Did you find a solution for your Brain E01 error code? My Brain coffee maker had this code today. I need a solution. Help!
