Question about Philips Ovens
Is a Philips system 600 oven hard wired or plugged in.
    Top Expert:
  • Philips Master
  • 58,596 Answers
DEPENDS ON WHAT THE ELECTRICIAN DECIDED TO DO . WE CAN NOT SEE IT TO TELL . CALL A LOCAL REPAIR SERVICE IF IT IS NOT WORKING
Posted on Feb 12, 2019
OVEN TRIPS OUT
Posted this several years ago. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Mar 04, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Thermostat on hot point stove
Posted this several years ago. Don't know if it's the same oven. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
Jan 18, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
How do you know if your oven is hard wired in or plugged in if can't see it?
The wiring should go to a cooker switch box...usually found at the back of an adjacent cupboard or on the wall. This will usually have a large red switch with a power indicator light and a standard switched socket.
On most installations of seperate oven and hob...the hob will be hard wired to the big red switch and the oven will be plugged in to the standard socket. So switch the socket off and see wether your oven is off...if the oven is connected to the big red switch instead then it must be hardwired...
Feb 13, 2012 | Ovens
Whats the difference between a hard wire and a plug in for a oven
A "hard wired" oven means the 10 gauge (3 conductor with ground) cable from the main service panel (breaker box) is connected directly to terminals on the oven. A "plug in" oven means there is a wall outlet into which plugs a cable connected to the oven terminals. The plug on the cable would be very similar if not identical to the plug on the cable used on a clothes dryer.
Charlie
Mar 13, 2011 | Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
Hard wired or plug in
if i bought a single oven with a three wire cable coming out the back with no plug, which i know is meant to be hard wired, are you saying i could fit a plug to this and plug it into a normal 13amp socket, reason i ask i ahve an oven which has packed in and it plugs into the wall at the back, if i fitted a plug onto the cable from a single oven below 3kw then are you saying i can do this?
Jan 20, 2010 | Ariston Technologies Ovens
Does the belling d841ss come with a plug or does it need hard wiring
If it is a single oven without hotplates, then it is o/k to use it with a plug,
If it is a twin compartment oven, then it needs to be hard wired.
Please rate my solution.
Thanks.
Oct 28, 2009 | Ovens
Ovens Logo
15 people viewed this question
Top Philips Ovens Experts
Craig Butler
Craig Butler
ray gallant
Al Schrader
Al Schrader
Are you a Philips Oven Expert? Answer questions, earn points and help others
