Question about Philips Ovens
Is a Philips system 600 oven hard wired - Philips Ovens
How to replace the thermostat on BP y-600
Turn off gas supply. Open panel on left side. Loosen the top and bottom unions. Remove thermostat capillary line from the oven. Now remove thermostat with 2 pipe wrenches. install new thermostat and attach assembly to the unions you loosened. Now insert the capillary line back into the oven.
Jul 27, 2014 | Bakers Pride Y-600 Gas Single Oven
Why only one side of oven burner will stay lighted fgf326asf
normally you have three types of baking methods.
1. Top only
2. Bottom only
3. Both. -use the setting to this configuration then you will be good to go.
OR
Only one part of your oven is working. THIS can NOT be due to a circuit issue. The other heating wire might be probably damaged. Get it replaced. Will cost you very less about USD5-10.
May 11, 2014 | Bakers Pride Y-600 Gas Single Oven
OVEN TRIPS OUT
Posted this several years ago. It's possible the oven sensor has gone bad or lost connection. Try cutting out the little plastic electric plug that connects the sensor to the oven wiring. Then hard wire it together with two small wire nuts.
If that doesn't work, you will need a new sensor, as we did. But when we installed it, we used the little plastic electric plug to connect it. Two days later it started acting up again.
The instructions said to hard wire it with two small wire nuts, but since it came with a plug it made sense to use it. Finally, even though it didn't make sense, I cut out the plastic plug and hard wired it. It's been about 3 years now and we've had no further problems.
THERE IS SOMETHING WRONG WITH THAT LITTLE PLASTIC ELECTRIC PLUG. YOU MUST NOT USE IT. HARD WIRE IT.
Mar 04, 2014 | Hotpoint SY36 Style Line Stainless Steel...
Replacing element in an old Chef Auto 600 Oven
Good news!
You probably can do this yourself.
Most appliance parts stores will "demand" you give them a model number, but if you find an appliance store that has a smarter older employee, he or she can probably give you the right one by seeing the old one.
Also know the element may be fine.
Older appliances sometimes have bad wires from old age.
When you take this apart, look carefully at the wires that are connected to the socket that the element plugs in to.
You may find the only thing wrong is a bad wire.
Know also that wire connectors for high heat things like stoves are sometimes made stainless steel, for the high heat.
God bless your efforts.
May 12, 2017 | Ovens
How do you know if your oven is hard wired in or plugged in if can't see it?
The wiring should go to a cooker switch box...usually found at the back of an adjacent cupboard or on the wall. This will usually have a large red switch with a power indicator light and a standard switched socket.
On most installations of seperate oven and hob...the hob will be hard wired to the big red switch and the oven will be plugged in to the standard socket. So switch the socket off and see wether your oven is off...if the oven is connected to the big red switch instead then it must be hardwired...
Feb 13, 2012 | Ovens
My phillips single oven has power, hard wired power supply showing lit. But when turning the oven on, no response. What should I do?
If you have a multimeter I would FIRST turn off the power and disconnect the heating element and do a continuity check on it. Phillips elements are not all that durable, so that is probably the problem, but it could be the thermostat or switch also. Some Phillips also have thermofuses that seem to blow for no aparent reason.
Jun 22, 2011 | Philips Ovens
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Nov 07, 2010 | Neff B1421 Electric Single Oven
I need to get 2 slates for y600 pizza ovens do you sale them.
When your looking for this part it is called the "Stone Deck"
36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
This is the Y-600-(old style) manual:
http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
This is the Y-600-DSP manual:
http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
http://www.bakerspride.com/manuals.asp
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
Hard wired or plug in
if i bought a single oven with a three wire cable coming out the back with no plug, which i know is meant to be hard wired, are you saying i could fit a plug to this and plug it into a normal 13amp socket, reason i ask i ahve an oven which has packed in and it plugs into the wall at the back, if i fitted a plug onto the cable from a single oven below 3kw then are you saying i can do this?
Jan 20, 2010 | Ariston Technologies Ovens
Ovens Logo
19 people viewed this question
Top Philips Ovens Experts
Craig Butler
Craig Butler
ray gallant
Al Schrader
Al Schrader
Are you a Philips Oven Expert? Answer questions, earn points and help others
