Question about Razor Toys
Accudart Razor Tech Dartboard, the razor wire is lifting.
SOURCE:
SOURCE: repairing electric razor
Questions,
What can be done to eliminate self-starting; slide switches which have become exremely sensitive to the touch and often times turn on when set down after use.
Slide switch covers no longer return to full "off" position. Ive had to use scotch tape to prevent them powering on when placed in suitcase, for example. Is this problem characteristic of Braun razors?
Can a nonprofessional open up casing to administer a very thorough cleaning? And where would one get an instructional schematic? Can one be obtained from Braun?
Thx!! Vince
Posted on May 25, 2008
  • 16 Answers
SOURCE: subsidy password for a razor
Send me the details for you handset:
What provided is your phone locked to?, I can provide a remote soluation for you.
Posted on Sep 16, 2008
SOURCE: motorola razor asking for passkey to bond with bluetooth headset
default pin for most bluetooth is 0000
Posted on Nov 20, 2008
shaggy067802
  • 76 Answers
SOURCE: reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
entries) and content you have downloaded
(including photos and sounds) stored in your
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Posted on Jan 16, 2009
  • 636 Answers
SOURCE: I have similar problems with my razor mx350.
sounds like the CDI box is shot. This should be located either under the seat or the left rear side of the fuel tank if memory serve me correct.Fairly cheap part 20- 25 bucks.
Posted on Jul 24, 2009
How do i clean my with my philips hq2000. instructions are in a different langue
  • 1 Set the Jet Clean System base on a flat surface and pull the cleaning reservoir out of the base.
  • 2 Unscrew the fill cap on the reservoir, pour Jet Clean Solution into the reservoir and replace the reservoir in the base.
  • 3 Plug the power cord of the cleaning base into and electrical outlet.
  • 4 Remove the protective cover on the razor head and place it to the side. The protective cover must be removed or the cleaning system will not work.
  • 5 Slide the razor head into the base, push back on the razor handle and press the locking lever down to keep it in place. The indicator light on the cleaning base will blink, indicating the razor is inserted properly and charging.
  • 6 Press the "On/Off" button on the side of the cleaning base. The razor will lower into the cleaning solution and begin the cleaning process, which takes approximately one hour. The razor will rise out of the cleaning solution when the cleaning process is complete.
  • 7 Lift up on the locking lever, remove the razor from the cleaning base and rinse the razor heads under warm water to remove any remaining cleaning solution. The razor is now clean and ready for use.
  • If you just have the solution and not the Jet Clean System, then I would presume you could soak just the heads in the solution to clean them and then rinse it off.
  • Jul 22, 2014 | Philips Norelco Hq200 Jet Clean Solution 2...
    Tip
    AVOID RAZOR SCOOTERS BUY VESPA OR HONDA SCOOTERS. THEY LAST FOREVER.
    Avoid razor scooters. I bought one at the goodwill thinking what a deal ... After new bats and wiring still no working. I got taken for a ride alright !
    Bought a Vespa and it works beautifully. Hondas are great too. Kids ride very summer. All summer same scooters . Razor is a scam.
    on Feb 06, 2014 | Razor E300 Scooter
    How will i know if its my batt or motor on off switch lites up red but nothing happens
    Lift the rear wheel up off the ground and apply the throttle, while watching the throttle lights. If the throttle light goes from green to yellow or red it shows that the battery voltage is dropping under a light load because the batteries are low in capcity - not holding much charge. Most battery places will load test the batteries free of charge to confirm this.
    Have a look at the trouble shooting guide here
    http://www.razorama.com/razor-installation-guides.html
    and the wiring diagram here
    http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
    Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
    What are the Standard diameter for Razor Wire?
    · 0.450m Welded Razor Diamond Mesh 6m
    · 1.200m Welded Razor Diamond Mesh 6m
    · 1.800m Welded Razor Diamond Mesh 6m
    · 2.100m Welded Razor Diamond Mesh 6m
    · 2.400m Welded Razor Diamond Mesh 6m
    Jun 22, 2011 | Razor MX350 DIRT ROCKET - BLUE
    Jul 24, 2009 | Razor Dirt Quad Bike
    Toys Logo
    43 people viewed this question
    Top Razor Toys Experts
    Bryan Mcphee
    Bryan Mcphee
    Level 1 Expert
    William Erickson
    Are you a Razor Toy Expert? Answer questions, earn points and help others
