SOURCE: Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
SOURCE: Maytag MDB-3 won't start, display flashes
Hold down the lighted "3" for five seconds to unlock the child safety lock
SOURCE: Wiring the 1750 watt eliminator direct to the main panel
DO NOT DO THIS! If I understand you correctly you want to have three ways to have 110 power in your motor home--- (1)Vehicle 12V to inverter to main panel. (2)Generator to main panel. (3)plug the main panel into 110V. If any two of these are connected at the same time and they are both live, somethings going to blow. That's because with AC, the two sources must be synchronized in their cycles very precisely. The utility company connects their power plants together on the grid only with the aid of precise controls. But the really serious problem is the same reason they invented transfers switches for home generators -- if you were connected to (3) and the power went out, and you connected (1) or (2) without disconnecting the dead (3), you will backfeed power to the line outside and you just might kill the lineman who is trying to fix the power outage.
SOURCE: LG inverter Direct Drive 7kg
UE is the error the washer will display if it detects an unbalanced load. If your LG washer was a model that contained the Ball sensor, it could be a bad part.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
SOURCE: getting an error code OE
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
