I Made some thing wrong in Panasonic Phone KX-DT3333 Hange Phone give bussy, I Need To Reset
According to the Technology Systems Consultants. Panasonic is under license and the KD-DT333 will have to be restored to original operation by a qualified technician.
You can go to...http://www.ask-tsc.com to find out more.
Also go to www.manualslib.com and search your phone and read the quick reference manual for yor KX-DT333.
Goodluck Hope this helped.
Ellen
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
SOURCE: panasonic KX-TGA236JXS gigarange phone is dial lock
panasonic KX-TGA236JXS give error dial lock
SOURCE: Panasonic KX-MB781 drum reset
I already answered this at some other place her - but here I go again: There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
SOURCE: Panasonic KX TCD715 Cordless Phone user's guid
I have solved the problem by downloading the user manual for Panasonic KX TCD715 from this page.
Thanks for your help!
Greetings from an island in the Atlantic,
HelleP531
