Offset errors are also caused by faulty/shorting speaker leads, and faulty speakers. A shorted tweeter or midrange speaker within a 3way speaker connected onto any of the speaker wires can also cause this error to arise. Playing the unit alot at excessive volume levels cause distorted sounds with in turn bring on the errors. Connect the unit with all speaker wires disconnected, if the error then comes up again, you have an internal circuit problem or an issue with the software. Cheers.
That error is normally a shorted speaker wire but starting the car won't cause that. Possible problem could be the dimmer wire was used as a ground by mistake. Lights come on when the car starts. Another is too high of voltage. Car rests at 12 volts but is around 14 when running. Was there a plastic piece on the red or yellow wire that got cut off during the install? They have a resistor inside that keeps the voltage down.
SOURCE: Error message at startup says..."Not enough space for music DB...must free up 6 MB of space.
your going to have to format your mp3 player.
SOURCE: Neptune FAV6800AW Top Load Washer: My Neptune washer is showing error code dc..Once i...
See this post Clutch Fix if you want to DIY I will help you.
Post back if you have questions……..Rich
SOURCE: My Neptune washer is showing error code dc..Once i...
See if my Clutch Fix post will get you started if your machine model type is a FAV6800A or FAV9800A.
Service Manual for reference. Sears Parts Direct for reference.
Your TDS is working or the machine would shake itself apart.
If you decide to DIY I will help you thru the process. If you decide to have it repaired show the Clutch Fix post to the repair tech it will help him help you back into service......Rich
SOURCE: DC Offsets on output - protection don't allowd to switch on
you don't want to do this( bypass the protection0
that d.c. output will burn the coils in your speakers with out making a sound!! you have a biasing problem
or like you said a d.c. offset problem it is best to work on this problem with out a load on the amp, this will allow you to trace back where the trouble is starting at. caps will cause this sort of problem but leaky transistors can also do this, even diodes.
this will require an experienced trouble-shooter.
