Heck out this site it has the alignmet procidure to set the squeltch and RF power output , Also a great easy mod for 400 yes 400 channels , enjoy http://radioaficion.com/cms/president-lincoln-ii-mod-400-channels
SOURCE: Squelch control on Galaxy DX-2547
You may have a bad transistor or detector diode that feeds the squelch circuit.If you can read a volt meter and Ohm Meter, and can solder ( Make your own repairs ) you may want to call Galaxy as the Techs there are normally very helpful.
Good Luck
Ed
NC Electronic
Mills, Wyoming
SOURCE: Cobra PR4750WX - how do I adjust squelch?
You are right there is no adjustment. You can however turn the squelch off and this maybe what is happening to you.
To turn the squelch off you press and hold the button that is just below the push-to-talk button for at least 5 seconds.
To turn the squelch back on, you either press (less than 5 sec.) and the same button or change channels.
When talking with a specific party or group, you should use the tone coded squelch (CTCSS) and that will mitigate the noise if you are not already doing that.
SOURCE: transmitting and receiving
RF gain should be all the way up. Turn the squelch all the way down. Turn the ANL/NB to just ANL.
Turn the dynamic up at least 3/4.
Once you have confirm you can receive and transmit, then you can turn up the squelch up until white noise just stops.
Make sure you are on 19 by the highway. Key up and say break break one nine, can some one give me a radio check please.
you should get a response.
Your RF gain is how much you receive. the higher it is the more you receive. In normal operation there is no need for it ever to be less the all the way on.
Squelch is just to knock out fuzz, and if you only want to hear people close not far. A little less then half way is a basic setting.
the ANL switch is the automatic noise limiter. if you have interference from your vehicle, like engine noise, turning this on will quiet that. If it is extreme engine noise then switch it to NB, noise blanker. It is just a more intense setting.
your dynamic is how loud your audio is. if its low or all the way down, you will not transmit audio loud enough for people to hear. If its a stock radio and has not been tuned, if you turn it all the way up, that is fine.
SOURCE: president Harry 2 classic does not listen (receive)
Hi and welcome to FixYa,
Initial tests:
If all of the above checks good, then signal tracing from the front end down to the audio amp. Would the schematics help?
Good luck and thank you for asking FixYa.
