SOURCE: Dell AIO A940 printer and Vista.
Starting ******* and doing drugs, screw this era. I hope the whole entire thing crashes!!!!!!!!!!!!
SOURCE: Color printer won't print color
Normal
0
Could have a corrupt driver.
Disconnect
the printer or at least be sure it is turned off. I'd do
both and when the CD software program asks you to connect the printer
to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of
the driver which has some known issues. Few steps will be required to fix this.
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
SOURCE: Dell 946 AIO printer won't stop beeping after firmware update attempt
Same thing happened to me....yesterday I went online at www.dell.com
to download the latest firmware & driver for my Dell 946 Printer.
After downloading the firmware the printer went haywire and is rendered
useless. It emits beeps and the green power light will stay lit then
flash every 3 seconds or so. There is no read-out on the lcd display.
I phoned Dell only to be told I should not have downloaded the firmware
and that Dell does not recommend downloading firmware. If that is the
case then why is the firmware listed on the Dell site with instructions
to do so? I was advised that no support could be offered because the
printer is out of warranty and was told to uninstall the printer and
re-install. I have tried everything, including uninstalling printer,
unplugging printer, etc. and nothing has helped. I have researched
online and note that this is a recurrent problem. This problem is
noted in the forums section of Dell.com - I have followed directions
listed in the forum section of Dell.com as noted (see below websites)
but this has not fixed the problem....
http://en.community.dell.com/forums/p/19261215/19444405.aspx?c=us&l=en&cs=RC1009777&s=fed
http://en.community.dell.com/forums/t/19167220.aspx?c=us&l=en&cs=RC1009777&s=fed
http://en.community.dell.com/forums/p/19256007/19422649.aspx
http://www.fixya.com/support/t416532-dell_946_aio_printer_stop_beeping_after
http://help.com/post/233917-dell-aio-946-printer-help
Since this seems to be a known problem and the problem is actually
caused by downloading firmware from the Dell site I feel it is an
injustice not to offer some type of support to rectify the problem. I
have always bought Dell products and advised others to do so, but with
this problem I feel that I will be changing my brand that I purchase.
I will be contacting Consumer Reports - I feel this warrants some type of recall!!
