Computers & Internet Logo
P
Patricia Posted on Feb 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mini display port and TCLRoku tv to macbook air, fonts are blurry/not HDMI/crisp at all. This includes fonts in terminal && Coding editors as well , can you help?
Jeffrey Groves
Level 3:
  • Master 573 Answers
  • Posted on Aug 26, 2019
Jeffrey Groves
Master
Level 3:
Answers
573
Questions
Helped
140501
Points
1832
Sounds like the resolution of your Macbook Air video adapter it much higher than what is supported by the Roku or TV.
5 Related Answers
Anonymous
  • Posted on Apr 29, 2009
SOURCE: TV won't recognize signal from a DVI to HDMI input adapter
I had a similar problem with a Mac Mini.  The problem was caused by a mix-matched resolution (the Mac tries to use 75Hz refresh rate, TV expects 60Hz).  The best solution I found was to remote into the Mac (I used LogMeIn.com) and change the resolution on the Mac from a remote computer until the image appears on screen.
Process: 1) Connect Mac to a normal monitor and install the LogMeIn server (or other VNC type application) 2) Connect the Mac to the TV 3) Connect to LogMeIn from another computer (preferrably one where you can see the TV) 4) Go to Applications / System Preferences / Display 5) Change the resolution to your TVs native resolution, and change the refresh rate to 60Hz
smarthome2
Frank Fulton
  • 1114 Answers
  • Posted on Jun 23, 2009
SOURCE: Macbook Pro DVI---> HDMI + Digital Optical Out = Problem w/ Sound
On the Sony The HDMI takes "priority" over all others, that's why you loose audio. If you run your DVI/HDMI to the TV and optical to the soundbar that would fix your issue. If your TV does not have Multiple HDMI inputs, you can get a DVI/Component adapter for your MBP then run it to the TV, or, If you have to have HDMI just to have HDMI, you can get a 2:1 HDMI switch and still have optical to your soundbar. Make sense? If youneed more help, just post a comment and I'll help some more.
killirien
Syzygy Darklock
  • 92 Answers
  • Posted on Jan 05, 2010
SOURCE: Macbook - Lg TV
Take a look at these discussions:
http://macosx.com/forums/hardware-peripherals/304718-connecting-macbook-lg-hdtv-rz-32lz55.html
http://discussions.apple.com/thread.jspa?threadID=1398546
Maybe a solution.
Good luck.
K.
Anonymous
  • Posted on Jan 14, 2010
SOURCE: can i connect my ps3 via hdmi port to component on my tv
You can get a PS3 adapter cable to hook up to the AVI 4 imput on your Magnavox projection TV (the green, blue and red video and red and whit audio HD imputs) You will have to change the dispay settings to 480p (that is the HD level of the TV). it is a bit tricky because you will have to start in the non HD imput, change the setting (the screen will go blank for 30 seconds) so VERY quicky unplug the yellow, red and white cable from the PS3 and plug in the HD cable. then press the X button or right on the direction pad and the setting should change over. switch to the AVI 4 imput and you should be good to go
TIP: have the HD cable plugged into the TV already to make it quicker so you just have to change the cable in the PS3...a bit of a silly process, but it should work.
TIP2: you can get the cable needed at blockbuster, future shop or best buy.
Paul Bade
  • 1818 Answers
  • Posted on Oct 13, 2010
SOURCE: I am trying to connect my macbook pro computer to
On the MacBook, check the Displays pane in System Preferences to make sure the settings for the external monitor are correct. It's possible that the system is not recognizing the adapter or it has the wrong resolution setting, so it's not sending out any signal that the adapter can use.
Many of the better DVD players and high-end video game consoles use HDMI. You can use one of those as a test signal generator to check the TV.
You may get better results if you use a DVI-HDMI converter, although you would need to get the DisplayPort to DVI cable. This will avoid converting to analog VGA signals and back to digital again.
Testimonial: "Thank you for giving me another avenue to explore."
1helpful
Are your hdmi wireless extenders apple compatible?
Consider the HRpart Wireless HDMI Display Adapter. Here are the key details:
4K Screen Mirroring: This adapter allows you to view audio, video, and office documents from a small device (like an iPhone, iPad, or MacBook) on a larger screen (TV, monitor, or projector) without messy cables. It's perfect for presentations, meetings, and exhibitions.
Wireless and Easy Connection: Setting up this wireless HDMI adapter is straightforward. You'll need a 5V/2A power source (which can often be provided by a USB port near the HDMI input on modern TVs and projectors). If the port is occupied, a battery pack can also work.
No Need for Wi-Fi: The adapter is self-contained and doesn't require an internet connection. Once connected to an HDMI input and powered, it displays a helpful screen for easy connection. You can stream movies, videos, games, and office files from your Apple device to a high-definition TV or projector.
Compatibility: This device is more suitable for Apple devices, including iPhone models (such as iPhone 7 Plus, iPhone 8, iPhone XS, etc.), MacBook Pro, MacBook Air, and various iPad models (iPad Pro, iPad Air, iPad mini). However, please note that it does not support HDCP-protected applications like Netflix, Amazon Prime Video, Hulu, and others.
You can find this HRpart Wireless HDMI Display Adapter on Amazon 1. Keep in mind that it's designed specifically for Apple devices and provides a convenient way to mirror or cast your screen wirelessly.
How to Fix MacBook Pro HDMI Not Working?
Having trouble with your HDMI port not detecting your monitors or TVs all of a sudden? Go to system preferences -- Click Display - Hold down the alt option key -- click the newly revealed Detect Displays button on the bottom right of the Display settings panel. That should solve 90% to 99% of issues if your cables and Macbook pro are good. This happens to me all the time when I try to plugin to a 4K tv at the office which is the exact same model I have at home. The one at home works while the one at the office never auto detects. If this did not fix your issue, check that your Macbook Pro HDMI port and HDMI cable ends are clean and free from debri and not damaged, double check that your HDMI cable is working on other devices, make sure your TV or display is powered ON, check that your HDMI cable is securely and fully seated, check that you're on the right input on your TV or Display, make sure the cable is not too long because HDMI has length limits depending on the cable and devices, and then force detect display again on your Macbook pro. If this still did not work, when it worked before. It's likely that your Macbook Pro, TV, or Macbook Pro HDMI port is acting up. I'd recommend taking in your Macbook Pro to the Apple store at that point to get diagnosed. Hope this helped
What cable is needed to stream Netflix to a Macbook?
If you want to use a TV as a secondary or mirrored monitor. All you would need is a Mini-DVI to HDMI adapter. Use the adapter to connect an HDMI cable between your computer and the TV. Once connected you will have an option to use it as a secondary or mirrored (exact copy of what is on your laptop) monitor. If you have one of the newer macbook pros you need a Mini Display port to HDMI adapter.
How to connect macbook pro to ASUS MX279H monitor?
Your monitor should have 2x HDMI and a VGA port and MacPro has Thunderbolt or a Mini Display Port. There is no direct way to connect your macbook to your current monitor. You'll need a Mini Display to VGA adapter. You can find this on ebay. Hope it helps.
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
How do I connect an HDMI Cable with audio support (mini display port) from my MacBook Pro to my Panasonic HD Plasma (TH-50PZ700U)?
You need a mini display port to HDMI Adaptor, You can either buy an expensive one from apple of a cheap one off ebay as they both do the same job just as well.
4helpful
3answers
How do you connect a mac to an HDMI device and can you get sound to the tv ?
Hey, you would need a Mini display to HDMI cable and unfortunately the sound cannot be ported through the mini display port.
I'm trying to hook my Macbook Pro to my TV (Samsung 50'' Plasma 720), I have all the cables needed to hook up sound and picture. I have the Mini display port to Dvi Adapter and Dvi to HDMI cable. My...
Hi
It may just be possible that DVI signal does not convert to HDMI signal. So in theory this may not be possilbe for you to get a result with your present attempt. May i suggest connecting to the DVI port of the TV. i.e Mini Display to DVI.
Regards
I have connected my macbook to my tv using mini
Later MacBook (Pro) use a mini-DVI connector that does not pass analog needed for composite or S-video. Was yours ever working? And most DVI connectors do not pass sound as seen by your cabling. You cannot detect display through RCA. You just set it in Sys Prefs :: Displays, try some other settings, although your seem right.
I have a white early-2009 MacBook and mini-DVI to HDMI adapter (monoprice <$10) and HDMI cable and have not connected the TOS-link for sound, yet--just slideshows at 1920x1080. You will get a much better picture digitally. -Ken
Top VIA Computers & Internet Experts
MegaByteMe
MegaByteMe
Aron
Steve Pack
Steve Pack
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
