Lands Phones Logo
D
Doreen CAMERON Posted on Feb 11, 2019
How do I take toll saver off my Vetech phone - Vtech Lands Phones
2 Related Answers
Al York
  • 39 Answers
  • Posted on Jul 16, 2009
SOURCE: how do I activate Toll
Toll Saver is the most confusing option with little or no information about it anywhere.
It overrerides the number of rings settings so that the answering voice mail cuts in after 4 rings or 3 if there are new messages. If you want to set rings to 6 or 7 or more, or have a consistent number of rings before voice mail cuts in, you have to turn off "Toll Saver".
From Telus:
Turn on "Toll Saver": *97 and hang up.
Turn off "Toll Saver": *96 and hang up.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Oct 02, 2009
SOURCE: toll saver
Toll Saver is a feature that changes when the phone answers if you have voice mail messages. If you have no messages, the phone answers after the 4th ring. If you have messages it answers after the 2nd.
If you call in and you hear a 3rd ring, hang up.
Carl
My voice mail doesn't work. I cannot get more than 2 rings on my incoming calls.
Press.MENU/SELECT > Ans. Setup menu > Ring Time submenu
Select a Ring time - Toll Saver, 2, 4 or 6 rings. Press MENU/SELECT once again to get a confirmation tone. The Toll saver setting is for if you are checking voicemail on a Long distance call, the call rolls over to the voicemail immediately if there are new messages
What can i do to change the ring counts? i followed the instructionsin the manual,but its still stuck on toll saver
We recommend you proceed through the process and ensure your press the [SAVE] button at the end of the ringer change procedure.
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1helpful
Toll saver
Carl
1helpful
How do i chck voicemail from a diffrent phone onmy uniden 3080
When you configure your phone, you also configure remote access. There is a code (one set by default at factory, or the one you chose when configuring it). To hear your messages when away, you call you number and wait for the machine to answee (welcome message). When invited to leave message, enter your code and listen to instructions. One menu item will ceratinly enable you to hear your messages. If you call often your phone long distance, you might find it intersting to activate toll saver option: With toll saver phone answers after 2 rings if there are new messages. If it does not answer after 2 rings there are no new messages and you hang up with no communication fees to pay.
Hope it helps.
How do I retrieve a voce message from a remote location? Thanks.
Hope it helps.
3helpful
Toll saver does not work. Ring count set to 4 rings
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Phone ringer
The box underneath the setup in the manual (mine's on page 13) describes what TOLL does. It can answer on the 3rd ring, the 5th ring, or if you have messages it will answer on the 3rd ring and not until the 5th ring if you don't.
You can hang up after 3 rings if the machine doesn't answer, because you have no messages. Other manufacturers call it TOLL SAVER.
Carl
1helpful
How do I activate Toll Saver on my EXA18580 series phone?
From Telus:
1helpful
Number of rings before recording answers
Choose how many times the line will
RINGS IS...” ring before the system answers a call.
• Set for 2 to 7 rings, or choose
Toll Saver 2/4 or Toll Saver 4/6.
• When set to Toll Saver 2/4, the system
answers after four rings when you have
no new messages and after two rings
when you do. Toll Saver 4/6 causes the
system to answer after six rings when
you have no new messages and after
four rings when you do.
• During setup, the Message Window will
display the number of rings (8 for Toll
Saver 2/4, or 9 for Toll Saver 4/6).
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
