SOURCE: Generator won't start & now starter will not shut off when it has power
I'm assuming the key ignition switch has been replaced with a new one. If this didn't correct the problem then the problem could be in the STARTER RELAY stuck in the 'on' position, or in the STARTER SOLENOID switch (located on the starter motor ) stuck in the 'on' position.
The STARTER RELAY should be located around or in a POWER DISTRIBUTION BOX . After locating the STARTER RELAY and gaining access to it, try hooking your charger or jumper cables, whatever way you want to power the battery to make the starter turn over, then while the motor is turning over then pull the STARTER RELAY out and see if that stops it from turning.
If it does then the STARTER RELAY is probably at fault and needs to be relaced. It the motor continues to turn over then the problem is more than likely the STARTER SOLENOID sticking in the 'on' position, and will need to be replaced. That should take care of the starter problem.
Next will be the 'not starting problem'. That could be fuel delivery, spark plugs, coil or ignition control unit. Would be so much more helpful to include date and make of an appliance when seeking help.
SOURCE: KIPOR KDE 6700TA 5KVA Generator
forget about the display read the manual and find out how many volts are needed to charge the battery....then
get a voltometer and disconnect the terminals from the battery and connect them to the voltometer while the generator is running...
find out what the reading is...if the reading is zero (0)...then post a problem on (no out put)...
if not.....then there has to be a mistake...
if it reads a voltage thats too low..then you AVR card is burnt out (AVR card is located in the other end of the generator (beyond the stator-side cover)...
Testimonial: "Khan sb. truly is a professional. "
