Sundisk 1.0 gb card - images show but cannot download
SOURCE: memory card says it's full
This can happen if there is a hidden recycle folder on the card. I had a similar problem that was solved by reformating the card.
SOURCE: files not getting saved in memory card
the samsung j 600 saves the bluetooth transfered files only in the phone memory.you need to move it to the card .and if ur phone memory is full then you can't download via blutooth unless you free some.
thank you
SOURCE: change the default memory to the memory card in samsung s3310
I have bought new Samsung S3310 mobile. I want to ask that, how to change the default memory to memory card because when I transfer any file through bluetooth it pop ups that phone memory is full please delete something. My memory card is 1 GB.
Please help me to solve this problem
SOURCE: Computer doesnt recognise camera
I highly recommend that you instead consider using a card reader to move the photos or videos to your computer. Card reader's do not require software (although Windows 98 and earlier may require drivers), are very inexpensive, are much faster downloading files from the camera, do not use the camera's batteries during the download, and are much less prone to file corruption of the photos during the download.
Really, it would be better for the camera user if one of these was included with the camera instead of the cable and bundled software.
You place the camera's card in the reader, plug the reader into the USB port, and your computer sees it as a hard drive. You simply copy/paste or drag/drop your photos onto your hard drive. For this simplicity, most professional photographers utilize card readers exclusively. You'll save yourself a lot of heartache if you convert to using one of these. Also make sure that you get a reader that is clearly stated capable of reading your card, particularly if you use SDHC, XD, CF, or MS cards.
Thank you!
SOURCE: communication error message on my canon s100
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
