Televison & Video Logo
Drio Rebelo Posted on Feb 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove (not disable) Hotel Mode
I Have one LG 65UV341C its a professional Hotel Mode TV, and i want to install some apps for the kids. Its possible to remove this mode and make the tv a normal one?
b1jqxk44
Level 2:
Habit-Forming:
New Friend:
  • Expert 157 Answers
  • Posted on Jul 11, 2019
b1jqxk44
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
157
Questions
7
Helped
36353
Points
395
Open up the menu and do a factory reset. This will make it a normal TV again.
5 Related Answers
Anonymous
  • 325 Answers
  • Posted on Sep 17, 2009
SOURCE: stuck in hotel mode 32 lg lcd
hold down MENU button for approx 5 seconds, then enter 1105 this will bring up the hidden menu then turn off the hotel mode.
Hope this Helps
Cheers
Little Dish Fitter
Anonymous
  • Posted on Sep 28, 2009
SOURCE: Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press 4725 (menu service appears), then search HTLSRC (position 090), then set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
Anonymous
  • 3 Answers
  • Posted on Feb 06, 2011
SOURCE: 32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
Anonymous
  • 11 Answers
  • Posted on Mar 19, 2011
SOURCE: sir,my tv has in a
it needs a bettrey
gopakumarg43
  • 76851 Answers
  • Posted on Dec 04, 2012
SOURCE: how to remove hotel mode from my lg lcd tv
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Hi, I some how put my lg tv into hotel mode and I don’t have the remote only one installed on my phone and now I can’t do anything with the app on my phone coz the tv is in hotel mode. Any way I can fix it...
Press both Menu buttons for 10 seconds
Simultaneously press and hold MENU buttons on the remote app and on the TV itself. The factory menu should appear. Let go of the MENU buttons and press one of them again once (either on TV or on the remote app). Now you should be able to disable hotel mode.
2answers
LG 37LG500H remove Hotel mode.
go into tv set up and turn off hotel and turn on home
2answers
Hi i have a LG BEJ32LP1DA tv in hotel mode, do Anyone know how to disable it? Thanks
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by type in " Hotel mode" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
How do i get my lg32lx4dc tv out of hotel mode?
You have to enter its service mode option to release the Hotel mode. For that, you should have its 'Service Remote Control'; not the user remote control. It will be best to contact the authorized service center for LG. google.com/+GopakumarGopalan
Service menu lg 37lh260h
your best and maybe only hope is to call the hotel unit for LG (not part of the main unit) to see if they will help or refuse you.
1helpful
5answers
I bought a 32LC5DC Lg tv from an hotel auction. The side panel doesnt work. The thing I need to find is how to access the "setup menu" inside the regular menu. I can get into the regular menu just fine,...
The only thing that would cause this is a lock!
If you ever forget your password, key in ‘7’, ‘7’, ‘7’, ‘7’
on the remote control.
If unlocking does not free up the unit menu then the unit has most likely had a software upgrade at some point to disable these functions permanently. This is normal hotel based systems in order to prevent them being used if they are stolen. In this case you will have to contact LG directly with Model no and Serial No details to get them to assist you.
4helpful
21helpful
4answers
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
