Question about Life Fitness Exercise & Fitness
Sir... in my life fitness treadmill display SCREEN there is massage continuously "Waiting for incline to reach home"
SOURCE:
vpaaf
  • 115 Answers
SOURCE: 9100 life fitness treadmill
Sounds like you need a new lower board replacement. You can get that for that treadmill by call lifefitness or sportsmith.com Please rate me good
I’m happy to help further over the phone at https://www.6ya.com/expert/howard_079189dd4959a511
Posted on May 01, 2009
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
gymtech
  • 18 Answers
SOURCE: Hi! i have a life fitness 9500HR treadmill and it
Unplug the treadmill . Remove front cover. On the right hand side if you are facing the front - in the siderail is a white switch that tells the treadmill it is all the way down. Check that it is in place and clean.
If you plug the treadmill in.{Do not touch any thing in the motor compartment} When you press start it should go all the way down [home] to contact the switch. You can also see the lit motor turn at this time before the belt will move it must be all the way down.
Posted on Feb 09, 2010
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
Error massage
follow this steps and fix it. Merry Christmas
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Reset:
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Life Fitness F1 Smart Treadmill
Quick start keys (quick start, speed, incline) do not work on the handlebar
1) Run the software callibration for diagnose and troubleshooting and fix it. Read your instruction manual, if you do not have go www.fitness.manualsonline.com or www. iconservice.com
see the block diagram for better understanding
God bless you
Jun 20, 2012 | Life Fitness 95Ti Treadmill 95 Ti
Sir, i have a life fitness 9500hr. I hit start screen reads incline inoperable. Everything else works but won't incline. Thanks
please check the fuse of 0.3 amp is located in the front of the machine revises this swicth home underneath the left side of the machine or check for side always in the left if the cables are not disconnected last step and check the capacitor is located on the hoist motor any question send me a message cardiotech_me@hotmail.com
Aug 15, 2010 | Life Fitness 9500HR Next Generation...
Unit will not start. it does work in maintenance mode. All fuctions work in the maintenance mold. When using the quick start or other setting to start workout, the unit does not start. " Please Wait " is...
Get back into System test hit enter it will automatically to a check once completed. Then go to Lift motor module Go to manual incline and go to maximum incline then to 0 incline then get out of system test unplug unit for about 30 seconds. Then plug unit in if this does not work the limit or home switch may be the culprit
Jun 29, 2010 | Life Fitness 9500HR Next Generation...
Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Apr 28, 2010 | Life Fitness 9000 Next Generation...
Hi! i have a life fitness 9500HR treadmill and it says incline error on the screen! and the incline doesn't work?? can i fix it somehow?
Feb 07, 2010 | Life Fitness 9500HR Next Generation...
Exercise & Fitness Logo
Top Life Fitness Exercise & Fitness Experts
Vincent_G
Vincent_G
Craig Butler
Craig Butler
Android Man
Android Man
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
