SOURCE: Green screen
No! that is difinitely not an easy fix. there is something wrong with the picture tube. it is the part that emits light and colors. you need to bring that to a local repair shop.
hope this helps.
thanks.
SOURCE: Insignia 32" TV Thin line across screen 1-2" from top
The original white line problem was caused by improper adjustment of the vertical size for which there is an internal adjustment.
The current problem could come from two different sources, one an adjustment again, the other from a capacitor that is losing capacitance and gaining losses; = sick.
If you are fortunate enough to have a surviving TV repair in your area, none of these problems is expensive to find or correct.
Don't be surprised to find the only TV shop operating out of a messy garage since those of us doing this kind of service are dying off and the price one can charge for labor has shrunken to the point that a real business address is too expensive to have.
SOURCE: there is a rectangular black box across the screen
in the customer menu--find the closed caption settings---you will most likely find the set has been set to TEXT 1---with the remote select either CC1 or OFF---the black box was for text (books) and was not ever used much---usually someone engages it by accident
