Coffee Makers & Espresso Machines Logo
Nat Posted on Feb 11, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I push the brew button on my Keurig MininPlus, only two ounces go into the machine from the reservoir. I have to lift and put down the handle repeatedly to get the water into the machine to heat and dispense the coffee. The machine is brand new.
Stephen Miller
Level 3:
  • Keurig Master 1,645 Answers
  • Posted on Feb 26, 2019
Stephen Miller
Keurig Master
Level 3:
Answers
1645
Questions
0
Helped
864986
Points
9471
5 Related Answers
Anonymous
  • Posted on May 01, 2009
SOURCE: keurig maker dispenses too little water when brewing
I found this solution on another post. Unfold a small metal paper clip and insert through the lower piercing needle of the cup holder to **** out any debris in the needle.Even a small piece of coffee or debris can slow the water flow through the cup.
Anonymous
  • 58 Answers
  • Posted on Jun 24, 2010
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Dec 22, 2010
SOURCE: does not brew coffee consistencty,
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
espressonist
espressonist
  • 1711 Answers
  • Posted on Dec 30, 2010
SOURCE: I have had my Keurig B60 for about a year and a
We have
here below a video link which is specifically for your case. The video is so
clear that we thing that any other words are useless.
http://www.youtube.com/watch?v=DqRs4Ott21s&playnext=1&list=PL88559E01E8136AA5&index=35
This one
will help if the above have not work out
http://www.youtube.com/watch?v=nIBvzWWI-LY&feature=related
If it does
solve your problem try also to do de-scale often
http://www.youtube.com/watch?v=l8diybgU6E0&feature=related
Anonymous
  • Posted on Dec 26, 2011
SOURCE: Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Keurig shuts off after i push the brew button?
Some of the most likely reasons by which Keurig keeps shutting off while brewing includes:
Machines require Descaling or cleaning.
The bottom of the k-cup is not punctured.
Misaligned magnet in water Reservoir
In this article , all these reasons are discussed in detail, which might help you
How do you purge a keurig coffee maker and establish the hot water reserve
With the water container in place, put a container under the nozzle and lift the handle as if you were putting in a K cup. Close it and push the brew button. You may have to repeat this a few times to get all the air out. Once you get a steady stream, you're done.
It delivers 8.5 ounces when i push the 10 ounce button
Your brewing system needs cleaned. I fixed this problem in my Keurig with a paper clip. Here's a video clip to show you how: http://www.bing.com/videos/search?q=how+to+clean+a+keurig+coffee+maker+with+a+paper+clip&FORM=VIRE2#view=detail&mid=CDB2C4A770BF1E840424CDB2C4A770BF1E840424
My Keurig says to prime
This video link below, from keurig, should get you back running.
remove reservoir, if you have a water filter, remove it and set aside. Use a damp non abrasive cloth and clean tank including filter screen. DO NOT DRY the inside with a cloth as lint may remain. DO NOT PUT in a dishwasher. Let it air dry. Reinsert the water filter. Put tank back into unit making sure it is aligned properly. Fill tank all the way up with clean water. Turn power on and attempt 3 WATER only brew cycles at the 6 or 8 ounce size. DO NOT USE A PORTION PACK.
If this doesn't work, you may have to clean the needles of the K-cup holder and / or the filter screen and water reservoir port.
If the problem persists you can contact you can contact Keurig at 1-866-901-BREW (2739) or Keurig.com
http://www.keurig.com/what-if-brewer-indicates-prime?cm_mmc=Google-_-Dynamic%20Search-_-Keurig-_-Keurig%20Homepage
Keurig won't work if there is a K-cup in however water flows through perfectly without it?
TRY..Lifting up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be.
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO IT:
Pour approx 48 ouncs of white vinegar into the water resevoir. PLacew a large mug on the drip tray, DO NOT use a K-Cup, press the brew button. Pour contents into sink. REPEAT this process until the ADD WATER idicator light, lights up. Let brewer stand for at least 4 hours while it is on. Discard any residual vinegar in the resevoir and rinse thorughly.
FILL the resevoir with fresh water. Place a lage mug on the drip tray and hit brew, again NO K-CUP, pour contents of mug into sink.REPEAT until "ADD WATER" is indicated.
YOU MAY NEED TO REPEAT THE RINSE CYCLE IF YOU NOTICE ANY RESIDUAL VINEGAR TASTE
GOOD
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
To begin, you will need the following:
  • 48 ounces of undiluted white vinegar
  • Large ceramic mug (do not use a paper cup)
  • Access to an empty sink
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
