Question about FoodSaver Kitchen Appliances - Others
Why will my foodsaver 4860 will not stay on? when I press the power button it flashes off and on. How can I open the drawer with the drip tray? It is stuck closed and will not open at all?
I have removed the bottom cover of the foodsaver, but the drawer will still not release and the foodsaver does not stay on. The last time I used it the vacuum worked and so did the sealer. The drip tray is definitely clean.
SOURCE:
  • 88 Answers
SOURCE: Foodsaver Food Sealer Vacuum V2240 T: Foodsaver Professional II Turbo. Vacuum pump work...
This is likely happening because the unit cannot detect that a vacuum has formed, and as a result, the unit never "turns on" the heating element to seal the bag, with the gaskets around the vacuum channel being the probable culprit. The Foodsaver gaskets will deform and/or dry out with time, just like in any device, but you don't necessarily have to replace them. I've tried this inexpensive solution on my own Foodsaver V2490, and it works perfectly.
Buy some food-grade silicone grease and apply it to both the upper and lower gaskets. I remove the gaskets and coat both sides with a thin layer of grease before replacing them in their respective channels. And since this grease will be absorbed and/or dry out with time, you will have to do this occasionally, so I also flip the gaskets (i.e. turn them over) whenever I apply the grease.
You can buy a 2 oz container of silicone grease at any dive store, or you can buy it over the Internet by searching for "Trident silicone grease".
This is a link where you can buy it for around $7.00:
Dolphin Dive Center
I do not work at this dive center, but I am a scuba diver and already had some grease that I use for the numerous rubber gaskets in my gear. The 2 oz. jar will last you several years, and you will find many other uses for it around the house since the grease will last longer than a spray.
Posted on Aug 02, 2010
  • 3 Answers
SOURCE: I have a Foodsaver 3420
Place a small piece of electrical tape over the contacts on the fluid tray. This will allow the machine to operate but you'll have to manually check the tray for liquids/cleaning.
Posted on Jul 31, 2011
SOURCE: FoodSaver vv384 will not pivot
Plug it in and let the sealing motor complete it's cycle to allow it to pivot.
Posted on Oct 30, 2011
SOURCE: FoodSaver v3825 (I believe it's
Mine did that when I interrupted the cycle. I plugged it in and let the motor fully open the sealing chamber then I was able to pivot open the machine.
SOURCE: foodsaver vacuum sealer tray full light
Tried the recommendation above, even have let it air dry for more than an hour, there is nothing moist around the three contacts. I, of course am in the middle of a huge project!
Posted on May 28, 2016
How to clean drip tray on FSV12927
Contact Foodsaver to ask how to clean the drip tray.
http://www.foodsaver.com/service-and-support/service-and-support.html
At the web site shown above, an online chat person will appear and ask your name and information to help you.
Service Support FoodSaver
May 14, 2018 | Coffee Makers & Espresso Machines
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Food saver is stuck shut
I experienced the same problem today. I forgot to reinstall the drip tray prior after cleaning it. I closed the Foodsaver back up and it got stuck in the closed position and would not open no matter how hard I tried. I would push the green tabs and attempt to rotate it as per the instructions and it still would not open. I was able to resolve the issue by taking a flat head screw driver and carefully prying a few inches in from the sides of the machine. More specifically, the drip tray is basically a rectangle catch basis with two half circles on either end. Place the screw driver at the location of the half circles and gently pry at the parting line where you would normally put the bags while pushing both the green tabs. Once the tray is reinstalled it should work fine. If your like me, you wont make this mistake again. Good luck!
Jun 11, 2012 | Tilia Foodsaver V835 Vacuum Sealer
FoodSaver v3825 (I believe it's the same as the v3840) will not pivot open so I can clean the drip tray - the release buttons are releasing, but it is hung up on something.
Sep 05, 2010 | Sunbeam JARDEN FoodSaver V3840 Upright...
DVD drawer won't stay closed
the open button could be shorted meaning the unit is constantly being told to open its tray i think its worth having looked at and i think your sons off the hook dvds are pritty hard for kids to muck up unlike the older vcr you would no belive the things kids would put in them best one i ever saw was a weat bix and a slice of toast.
good luck
May 15, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
Dredge drawer full and it is empty
Hi
One thing you want to make sure you do is leave the machine on when you remove the drege drawer other wise the machine doesn't know that you emptied it. Remove the drip tray and pull the empty drawer out about half way and leave out for 15 seconds. Then push the drawer back in from the right front side with 1 finger. That way you make sure that you engage the switches in the machine. If you slam the drawer in you can pull it away from the switch and it will say drege drawer missing. If you put the drip tray back in, it can sometimes lift the drege drawer and disengage the switch. There is a notch in the right side of the drip tray that has a flashing on the back side of it. You can remove about an 1" of the right side of the flashing and it will stop the lifting of the drege drawer. Remember to leave the machine on when you empty the drege drawer other wise it doesn't know.
Jul 17, 2009 | Saeco Royal Professional Espresso Machine
I have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray...
same equql problem....?????
Can you help?
i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. i have a denon 1720 dvd player. When you press the power button it comes on for 3 seconds then the power button turns back red and powers off. If you press the eject button within the 3 seconds the tray opens and the power button stays green. As soon as you close the tray the power agin goes to red. Can you help? thanks thanks
Dec 21, 2008 | Televison & Video
Disc Tray Problem
That is how the X-Box works. It doesn't stay open, because if it stood open and it accidently dropped or anything, the drawer would break, and that would cause alot of problems with Microsoft. Thanks for using Fixya!
Jul 11, 2008 | Microsoft Xbox 360 Console
Kitchen Appliances - Others Logo
Top FoodSaver Kitchen Appliances - Others Experts
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a FoodSaver Kitchen Appliances - Other Expert? Answer questions, earn points and help others
