Question about Jabra Radio Communications
Does the jabra eto7 have a battery you can change
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Jabra BT500 won't power up
    If you can try a different charger, try that. try charging with USB cable if not. Try your charger on another headset if you can. I think the charger is the problem. If no change every way, here is the link to the user manual if you need it; http://www.jabra.com/Sites/Jabra/NA-US/pages/SupportProduct.aspx?productid=3c063d26-e62b-4b4d-9613-c10134a79cf3 Page 7 has the toll-free tech helpline which is probably worth a check in case they have any ideas before opening it up. If still no luck, and you want to open it up, first thing to look for is the battery. check any connectors are on properly. try charging for a while and see if battery gets warm/hot/no change. See if there are any technical specifications or part numbers written on the battery and I can get more info to see if it can be checked and if it is worth replacing. If you have any trouble identifying the battery, try posting back a photo of the inside and we will see what we can do. Hope this helps :)
    Aug 17, 2007 | Jabra BT500 Wireless Headset
    Jabra bt530 does not hold charge
    Did it used the charge before?
    How long do you have it for?
    How often is it required that you change your battery?
    Is your charger really connected to the power socket?
    Does it show a charging light?
    Feb 11, 2014 | Jabra BT530 Bt HDst Black Bluetooth...
    Jabra wave battery suddenly won't charge
    The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
    Jan 13, 2014 | Jabra Wave Bluetooth Headset
    Jabra BT2080 - been working well, charges and shows green charged light but bluetooth doesn't light up and unit shuts off.
    This problem is mostly associated with the battery of your device. In some cases, the battery is most likely to have expended it's lifespan.
    In this case, all you need to do is to change the battery. It is advised that you get a professional to change the battery for you as trying to do this yourself could lead to a damage in the device.
    Apr 23, 2011 | Jabra BT2080 Bluetooth Headset
    How to replace a battery
    I checked the manual, available here ; audio.manualsonline.com/manuals/mfg/jabra/bt330_1.html
    I can see no mention of battery replacement.
    I looked on eBay and found no-one selling replacement batteries for the BT330.
    The battery type used in headsets only lasts two to three years, so you may have to replace your headset. I noted a Jabra model BT2040 available that uses non rechargable AAAA batteries.
    Feb 11, 2011 | Jabra BT330 Wireless Headset
    Jabra 5050
    Sounds like you've used this thing quite a bit, eh? Rechargeable batteries only last for so many charges. If a charge doesn't last very long anymore, you probably need to change the battery. This is not for the technically challenged. The battery may just pop out of a slide cover, or may require practically breaking the device in half to get it open, then unsoldering the old battery and resoldering a new battery in place.
    But, it definitely sounds like you need to replace the battery. You may have to consider a new one - sorry.
    Apr 21, 2010 | Jabra SP100 Bluetooth Wireless Adapter
    My jabra bt 160 wont work after a long time of not using it, and how to pair it to a device?
    Your battery may be completely discharged. contact Jabra to fix this problem. Jabra has a lot of problems with their batteries!
    Feb 22, 2010 | Jabra BT125 Headset
    I charged the BT350 using the Jabra Charging
    I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
    Thank you,
    Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
    Jabra BT150
    The first dude is an idiot! The battery is toast go buy a headset that isn't as old as this Jabra! I also have the issue & no didn't plug it in wrong...it only goes one way! Mine sat for a few years unused & now will not charge...You can get newer headsets pretty cheap! Look around!
    Apr 29, 2009 | Jabra BT150 Wireless Headset
    Radio Communications Logo
    46 people viewed this question
    Top Jabra Radio Communications Experts
    Bobby G
    Bobby G
    Damen Wong
    Damen Wong
    Jerry Greenberg
    Jerry Greenberg
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
