Question about Watches
Surface watch manual? - Watches
    Top Expert:
  • Watches Master
  • 58,111 Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
I need locate instruction for a surface watch
Try Googling (surface)(model)(manual) without parens.
Jun 06, 2017 | Watches
Setting up the Surface 33416 watch.
sadly I would have to have it in my hand to tell you .
Nov 19, 2015 | Watches
Can you help me set my surface watch model 33009
Are you sure the number 33009 is correct?
Most Wenger watches have 5-digit numbers starting with 7.
There is a Swiss Military Manual here:
https://www.wengerna.com/stuff/contentmgr/files/6/540159dc9885eeee1a65eec748ed4597/pdf/swiss_military_watch_manual_2012.pdf
May 07, 2014 | Wenger Swiss Military Classic Field Watch...
Hi, I have a casio protrek PRG-80T-7V(triple sensor). I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch....
Try to reset the watch.But first be sure that you capable of doing this.
Reseting the watch procedure:
1)Remove the back cover.Be sure that you have the appropriate screwdriver.Keep the 4 screws safe, not to loose them.
2)On the chassis of the watch (metallic surface) somewhere there is a hole with AC (All Clear) written nearby.
3)Use one little thin retracted paper clip (not totally retracted).Insert the retracted end of the clip into the hole, gently, until it touches the end and with the upper part of the clip contact the chassis (metallic surface). Wait for 1-2 sec and remove the clip gently.The watch is now reset.All functions have been set to factory settings.
4)Put back in place and with caution the back cover, respecting right (up-down) positioning and taking care that the O-ring gasket is well in place,first.
5)Holding in place with one finger the back cover,screw back screws gently and without applying excessive force (delicate job) until you meet resistance, in the following order:
Up-right,down-left,up-left,down-right.
After setting the time/day/date etc try to calibrate compass both ways as you did before.
I hope this will solve your problem.
NOTE:Again,be absolutely sure that you are capable of doing this.
It is a bit delicate job.If not,you better bring the watch to an official CASIO service center.
Apr 27, 2017 | Casio Protrek Triple Sensor PRG70 1BVDR...
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Battery replacement. can not get back cover on.
mcdevito75 here, First look for any for any notches or cut outs on the cover, there should be a cut out on the cover for the stem, at this point line up the cut out with the stem, place the watch on a sturdy surface, Table, counter top, make sure the watch is completely flat on this surface with the cystal (glass) faceing up, now place the palm of you hand on the crystal and with even pressure press down slowly and evenly, the back should snap on.
Jun 16, 2010 | Pulsar PXH225 Watch
I inserted a new GE super mini mouse into my laptop and I am unable to use the mouse. What do I need to do to make it work?
I lost the manual for my Surface men watch please let me know how I can get one. Pauline
Jan 23, 2010 | Watches
Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Dec 03, 2009 | Watches
I can't stop hourly chime in my Timex Indiglo
1-Place watch on hard flat surface.
2-Hit repeatedly with large hammer.
If you should need further assistance just ask.
Jul 24, 2009 | Timex 27191 Wristwatch
SCRATCH ON BLUE BEZEL OF WATCH
If it a scratch on a brushed surface try one of these watch Brush pens
Here only a couple bucks
If it is on a polished surface
try a cape cod cloth here
both are indispensable watch collectors items.
Dec 30, 2008 | Tag Heuer 2000 Aquaracer WAB2011.BA0803...
Watches Logo
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
