It fills up with water to the right level but never gets past the prewash cycle.Ive cleaned the small plastic container with the hose to the pressure switch but it still only gets to this point. If i restart it after it stops it pumps all the water out again and refills again and times out again stops and the eco light flashes. Can you help me.
Read your Owners Manuel or look it up on google
I had this problem and discovered it was due to a leak. The float switch attached to the bottom panel was operating. Pull out the mains plug, tip the machine on it's side (water will escape so get a mop ready), remove the bottom panel, 3 screws front and back, disconnect the connector from the float switch. Tape the connecter up out of the way and stand your machine back up. Try running it now. If you have a leak somewhere then you will get a puddle under the machine. If no leak, then I would suspect the float switch itself.
I went looking for a float switch but I couldnt find one on my machine...i could see it on a exploded view diagram on a parts site but I cant see any float microswitch on mine or am i missing it as it is somewhere else ...is it right in the front as I can see provision for one in the plastic housing but there doesnt seem to be one...any ideas? Or does it use the pressure switch to get past this stage of the cycle when it fills up.
SOURCE: Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
SOURCE: Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
SOURCE: Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
SOURCE: Dishlex Global 300. Eco light flashing and nothing happens.
could be the water inlet valve or solenoid
