Washing Machines Logo
Charles Fleming Posted on Feb 10, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE WDSR2080D -- The cycle selector spins but does not engage and does not come on when pull button out to start.
zoe dee honea
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on May 17, 2020
zoe dee honea
Expert
Level 2:
New Friend:
Answers
45
Questions
Helped
18413
Points
141
Behind the timer knob if you pull it out you will see a plastic horse shoe shaped pin clip that holds the knob on the shaft. could be a very cheap fix if it has broken or worn so that it does not let the shaft all the way out.
GE WDSR2080D -- The cycle selector spins but does  - 1c890796-a2b5-44f3-8184-4c3c547e38ff.jpg
5 Related Answers
Anonymous
  • Posted on Jul 13, 2008
SOURCE: Washing machne problem
The help that you gave me was completely wrong. The support ring was okay. I solved my problem by buying a new timer and control knobs. The teflong 'gears' were worn out so the knobs rotated freely.
Ronald Nelson
Anonymous
  • Posted on Aug 25, 2008
SOURCE: My Ge wssh300gww will
It is probably a clogged pump (don't look in owners manual for info - curiously it isn't in there - just says call tech - bolocks!)
Remove 2 screw on front bottom panel.
Remove cover.
Plastic boot and pump are on right had side. Clean out - and use the change to buy a drink - celebrating the fact you didn't have to spend hundreds on a tech!
Anonymous
  • 550 Answers
  • Posted on Sep 06, 2008
SOURCE: The start button only buzzes
start button energise a relay that latches open and provdes the current path for the very heavy draw of heaters, and motor.
the relay is dead, or dying and instead of locking open is fluttering like a doorbell (buzz buzz).
Not a repairable item, it is replaceable and not very expensive, much less than a new dryer, last one purchased was $29.99
Relays are common to many dryers, the local parts guy will have one to match if you take the dead one.
typical relay looks something like this, not all are transparent
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Jun 14, 2009
SOURCE: My GE WDSR2080D washer won't spin or drain.
The crappy designed mexicanical lid switch device has faile, jump it out. Remove the front panel and then you can get the top off to access this problematic lid switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • 28 Answers
  • Posted on Sep 06, 2009
As the other posters mentioned, the problem with draining is most likely caused by a clogged filter. Mine had 14 cents, 2 zip ties, and a bra wire stuck in it. Here is the process (after many hours of swearing and bleeding) so that it should be pretty easy.
The first step is to tilt the washer back so the front is 3-5 inches off the ground. Prop it up with something. To remove the front lower panel, there is 2 phillips screws under the bottom edge. Remove the screws and the panel should drop down off the pegs holding the top edge in.
Inside, attached to the drum you will see a rubber boot with an accordion sleeve which contains the filter. There is 2 green spring hose clamps (the source of many expletives) and a silver phillips screw on hose clamp. To get at the filter, you should not need to, nor do you want to, remove the green spring clamps. You will spend hours trying to get them back on.
I have attached a picture for reference. Unscrew the silver clamp (large one, closest to drum) and pull down the sleeve to get access to the filter. If you are full of water, you can slide a pan inside the machine and just pull down the edge closest to the pan to drain until the water is gone. Reach down into the accordion (gross) and grab the filter. It has a lip on it so you will need to work it out through the accordion thing, but it likely has some really gross stuff in it. Clean it out, wad it back into the boot, and reattach to the drum. Dump about 2 gallons of water into your drum to make sure you are not leaking. Switch the knob to spin cycle and hit start 2 times. It should drain the water out within a couple seconds.
3helpful
Washer stuck on agitate cycle, with no water. if time is manually advanced to rinse spins cycle, you can hear the pump but it will not advance to spin
Pull the front panel off the machine and check the small hose running from the tub to the control panel ( left hand side of tub). Pull off the hose and you might see a build up in the end of the hose . Clean and re-attach .
Final rinse cycle never engages
does all the water drain out? will the machine spin on any cycle? does the timer advance to off?
if the lid switch fails to activate then it would not let your machine spin on any cycle.
you should also check to see if cold water is coming into the machine. most machines rinse on cold water and if the water valve for the cold side fails - this could also be a cause.
2helpful
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
When my washer gets to the rinse/spin cycle it won't spin.
The problem may be the selector switch.
Your best bet is some testing. I would recommend an ohmmeter and a voltmeter. Check to see that the switch is putting out a signal and that the motor is getting power as well.
Stops running after wash cycle emptys. the timer keeps running but the rinse and spin cycles do not engage.
Can you make rinse and spin occur by turning the control by hand to those positions? In any case, suspect the timer control itself, or maybe some of the wiring has come loose from the controller.
Wash/soak cycles will not work
Just cycled thru the switch several times and all of a sudden today it started working on the wash cycles
G.E. washer model wdsr2080d2cc
my machine will do nothing but spin, is there a reset button
or do you think a part needs replacing?
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
