SOURCE: casio PCR-T275 keeps beeping
Hi.
It can be tricky. If there is an error code on the display then this can point to the problem. The most common is e01 which means the key has been turned before finishing in another mode.
If there is no error number, then check:
1. Printer cover is closed securely and there is plenty of paper in it.
2. Make sure there are no stuck keys on the keyboard and no drink spillage on the keyboard.
3. Try turning the key to each position and press CLEAR (C) then CASH in each position (eg REG C CASH, X C CASH, Z C CASH, PROGRAM C CASH)
If these don't work, try to describe the beeping. Is it constant or pulsing on and off? What is on the display? Does it change at all when turning the key or pressing buttons? Can you still feed the paper with the FEED button?
Mark
SOURCE: programming of the casio pcr-t275
Hi program the taxes like the book says but fix the gst rate, then go to program mode and push 1 subtotal, then push t/s1(taxtable 1 which is gst) and the dept number you want to use, then subtotal and cash and that will be the dept you will use for just gst. Hope I'm making sense. Took me forever to figure this out.
SOURCE: We bought casio pcr-t275 cash register from
Here is a link to the user manual. You will be able to download and save it to your computer, or print it out for future reference.
http://www.casiomobile.com/sa/products/downloads/manuals/PCR-T275_E030624A.pdf
SOURCE: I have a casio PCR-T275 cash register and I need
Hi.
Has the machine been programmed for tax previously, or is this a new tax setup?
If anyone needs a manual for a Casio PCR-T275 cash register, go here:
http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
SOURCE: how to void a sale on casio pcr-t275-l cash regester
This is a very simple model, so there are only two ways to remove items in a sale.
If you enter an incorrect item, press ERR CORR to remove the last item.
If you want to remove a previous item, or return an item after a sale, turn the key to RF (refund) mode and key in the item the same as you did in REG mode. This will return it so that it does not affect the daily total.
If anyone needs / looking for a Casio PCR-T275 manual, try here:
