Question about Fossil Watches
The size battery for a Fossil watch PR 5196 - Fossil Watches
    Top Expert:
  • Fossil Master
  • 62,150 Answers
THE SIZE THAT CAME OUT OF IT
Posted on Feb 11, 2019
SOURCE:
SOURCE: Fossil ES1592
watch press
Posted on Jun 19, 2008
SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Posted on Nov 09, 2008
escapement
  • 2338 Answers
SOURCE: Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
Posted on Jan 26, 2009
escapement
  • 2338 Answers
1)Get the battery out again and check for power. 1,5 Volt batteries should be 1,52V - 1,54V and the 3Volt batteries shold be 3,1V - 3,3V in charge.
2)Take the hardened steel needle or watchmakers screwdriver and clean (scrape) both contacts off any visible residue till they are shiny. aaaaaaaUce dust blower to get rid of scrape-offs.
3)Make sure the contacts are touching the corresponding battery side only and not shortcuting the battery.
Do not forget to rate please.
Posted on Mar 07, 2009
  • 103 Answers
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
Posted on Aug 04, 2010
Which 3 battery sizes go in fossil BG2131 watch?
Take your Fossil watch to a jeweler who will identify the battery type and may even be persuaded to install replacements. All for a reasonable sum.
May 24, 2018 | Fossil Watches
I have a Fossil ES-9722 wrist watch without a battery. What size battery does it need?
You want to know type, not size. Take the watch to a jeweler who, for a few dollars will replace the battery.
Oct 17, 2016 | Fossil ES Watches
Need watch battery size for a fossil blue watch model number Tl-5073
  • Remove back
  • Find battery mounting. Note for later battery installation
  • Read battery type (not size)
  • Obtain exact battery replacement
  • Remove old battery; install new
  • Check operation
  • install back
  • Set watch
Sep 09, 2016 | Fossil Watches
Need battery size for blue face round fossil watch
SR920 that is the size of the battery of your watch
Jul 09, 2011 | Fossil Arkitekt watch
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
Aug 26, 2010 | Fossil AM3784 Wrist Watch
I don't have the original battery to my watch, and am looking for a replacement. The watch is a Fossil Arkitekt FS-3031
<P>Thank you for contacting FixYa.</P><P>Unfortunately, unless it is stamped on the back of the watch, or it is in your manual, there is no way of knowing the battery that goes in any watch without the old one, or very accurate sizing of the area it goes in. You can try to contact Fossil via this link:</P><P><A href="http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html">http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html</A></P><P>Best regards.</P>
Aug 24, 2010 | Fossil Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Watches Logo
61 people viewed this question
Top Fossil Watches Experts
Arturs Kalnins
Arturs Kalnins
Ray Murphy
Are you a Fossil Watch Expert? Answer questions, earn points and help others
