SOURCE: Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
SOURCE: My recoil starter will not pull back the recoil
Go to smalleng.com they have free how to videos for just your problem, check it out it's a pretty cool website.
SOURCE: doesn,t engage with engine
sounds like the dogs and or springs are worn.When you had the cover off the machine did you check that the dogs would freely move out when the rope was pulled? They some times stick and will not engage.
SOURCE: my ryobi model ss 30
was there 2/s oil in fuel?...if so then starter clutch could have failed locking everything up
SOURCE: I have a troybilt tb-144 4 stroke mini tiller.
Troy bilt TB144 loses compression won,t start. Help
