SOURCE: Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
SOURCE: washing machine error code f04
ok these machines are great and they make it very simple F04 means cant drain which usually means money or bits and bobs stuck in pump impeller. On the front of the machine remove the bottom right hand plastic cover by hand this is where the access to the filter and pump can be found, you will see a black cap about 3" which can be unscrewed you may need pliers or something to grip it and turn it, have plenty of old towels ready as the water in the machine will begin to come out when you unscrew it(anti clockwise), just unscrew it a little until the water trickles out and mop it up with the old towels until the water stops then continue to unscrew anti clockwise until you are sure the thread is no longer gripping you cant over unscrew so if in doubt just keep unscrewing....then it needs to be pulled out toward you, you will probably need grippers or pliers for this just wiggle it out and remove it, look inside you will see the drain pump impeller, put a finger in and feel for whatever is obstructing it and remove, now use a finger to feel for the inlet that comes into the chamber from the left, use a finger to feel inside this pipe and remove other bits and bobs in the pipeline that were ready to find there way to the pump, once you have removed whatever is in there clean with a rag the thread and scale and make it nice and clean. In your sink wash the screw cap and little white filter piece that is attached to the cap and careful so as not to cross thread it push and then screw it back in making sure the filter solid plastic part is facing toward the inlet pipe you cleaned earlier as its that solid part that prevents (should prevent but didn't or you wouldn't be doing this) large objects finding there way in to the impeller chamber, screw the cap in and restart the cycle and your done, easy repair anyone can do it..... Don't forget to send me your luv if this works for you!!... Nick (at) 2xx.co.uk
SOURCE: f04 error message on a bosch exxcel 1400 washing
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
SOURCE: what does error f04 mean on a bosch washing
It means that the water is not draining fromthe machine inthe time allowed by the controller.
1. Switch off the machine and disconnect the mains power.
2. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray.
3. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
4. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
5. Reconnect the power and switch the machine on.
If the problem persists then do the following.
6. Switch off the machine and disconnect the mains power.
7. Check the electrical connections at the pump and make sure it is operational.
8. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
9. Makes sure the pump appears clear and that the impeller looks in good condition.
10. Reconnect the hoses and then reconnect power and switch the machine on.
11. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
SOURCE: error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
