Here is the manual.
If it is an LED bulb it may be bad. LED's tend to blink constantly when bad.
https://manualsbrain.com/en/manuals/908701/
SOURCE: goodman heater will not start
I cant be sure but usually the constant blink on some boards means reversed polarity. Check your HOT (L1 - Black) comming in to the connector box and the your NUTURAL (L3 - White) should not read any volts to ground (not more than 12 volts on an electronic VOM). If this is opposite remove power and reverse black and white wires and retry.
HOPE THIS HELPS PLEASE GRADE ME ACCORDINGLY and GOOD LUCK!
SOURCE: my KitchenAid dishwasher will not run. Start light is blinking
Make sure the controls are not locked. Some units have the ability to lock the controls so that kids cannot turn on the dishwaher. You can also try unpugging the power to the unit from under the sink for about 10 minutes and then plug it back in. This may reset the control board if it has a fault and stopped from error code.
SOURCE: Auto clean on electric range
Try replacing the "logic switch" attached to the oven locking mechanism. I had the same problem and it worked for me.
SOURCE: Model CCA36FCC Mfg No P1258004C Issue: The
find another teck sounds like its low on freon if it has a txv it could be malfuncitioning!!!
SOURCE: Kitchenaid vented microwave KHHS179LSS-5 surface
Press
the "Off/Clear' button to cancel anything on the display, and reset the
microwave. This is a soft reset and will simply get you out of any
program you have started. Press it when the cooking complete reminder
appears on the display.
Perform
a hard reset. Pull the plug out of the wall power supply, and wait a
moment. Plug the microwave back into the wall power supply to reset
any anomalies with the microwave's memory. You will need to reset the
time of day if you perform a hard reset.
Reset
the time of day. Press the "Clock" button, and turn the dial to set the
hours. Press the dial to enter. Follow the same procedure for the
minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
