From the information you have given, line 1 is shorted to ground or you have a wiring issue from the power source. You will want to be very careful as this sounds like a situation where you could easily get a shock. I would start by checking my power source with a volt meter test line 1 to line 2 = 240V, line 1 to ground = 120V, line 2 to ground = 120V. If this is all correct a good visual inspection of the oven wiring and circuit boards, if it is not correct contact an electrician. If nothing is found on the visual inspection it is time to start testing and with what you are describing the problem is probably in the main board though it could be in any of the components.
SOURCE: Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
SOURCE: Kenmore stove oven does not shut off
Please contact to [email protected]
or www.paltronics.eu
I have access to tools
and technology
and I can usually fix those boards for 30%-60% market price
Sincerely Chris
SOURCE: Kenmore oven Model 911.30169792 Control panel lights are on
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: my start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
SOURCE: ge double oven jtp56 bottom
Welcome to FixYa.
It sounds like the hi-limit safety thermostat may be tripped, I haven't seen anywhere in the post dialog where this has been mentioned or that you've checked it though, have you checked ?
Unfortunately it is the non-reset type hi-limit on these ovens, though it may sub to the reset-able type when a replacement is purchased ( if the oven is indeed a JTP56 model ) It is shown here and is behind the grill between the two ovens...
It is located between the two ovens behind the grill where the lock is for the lower oven, so it is a challenge to get to, but the part #WB24K5142, It is available at "repairclinic.com" or "searspartsdirect.com" on-line parts vendor for approx. $10USD. but if you jump it out to test it and then replace it, we can get you back up and cooking.
** Please turn off the breaker before attempting any service please...safety first **
Let me know how you make out or if indeed you've already checked the hi-limit thermostat. I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
