SOURCE: LEXMARK x5150
I have one of these and it has had similar problems, errors not listed in the manual. I don't use mine much, so I took out the cartridges and cleaned them as well as the contacts and other surfaces. It didn't help. I replaced the black one and it works now. Your printer cartridges only last so long, even if you don't use them they expire and won't work. Once you remove the cellophane covering, they don't have a long life. Your printer will work without the color cartridge by the way. When the "no color cartridge" error appears, just click continue and it will print in black and white. Don't know if this helps, since your post is older, but I hope it does!!
SOURCE: my Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Your print cartridge has shorted.
1. Power off your All-in-One and unplug it.
2. Plug in your All-in-One again and turn it on.
3. Uninstall and then reinstall your cartridges.
4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
1. Power off your All-in-One.
2. Use both hands to lift up the scanner unit until the scanner support holds it open.
3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
4. Remove the color print cartridge.
5. Lower the scanner unit until it is completely closed.
6. If the error message reappears, replace the black print cartridge with a new print cartridge.
If it does not repeat steps 1-3 and then go to step 7.
7. Reinstall the color cartridge and remove the black print cartridge.
8. Lower the scanner unit until it is completely closed.
9. If the error message occurs again, replace the color cartridge.
10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
11. Lower the scanner unit until it is completely closed.
12. If you receive the error message again, replace both cartridges.
SOURCE: lexmark fax machine series x4270 has an error code saying #1200
Please click on this link :
http://support.lexmark.com/perl/support/support.cgi
and then click on support ,once the page is opened please center X4270 in
Search by Model ,after that choose Lexmark X4270 ,after seconds a page will open and then in
Search the KnowledgeBasePut this number and follow the steps given:
ENUS23485
good luck...
SOURCE: I have a lexmark prospect
Updating the firmware for your Lexmark Pro200 series will help fix this problem. You will need to get rid of the error first before you can successfully update your printer. Follow these steps:
1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
3. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button.
4. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. There'll be more than one download for your model, try the top download first.
6. Once the firmware update is successful, reinsert the printhead by following the steps on your printer screen.
Source: There is a Problem with the Printhead
SOURCE: my lexmark intuition s505 has a printhead error
It sounds like a problem with the printhead. If your printer is still under warranty, please contact our technical support team to have the printhead replaced. You can find the contact details at support.lexmark.com.
If it's already out of warranty, you can purchase a printhead here: http://bit.ly/IZYhWo
I searched the interet for that error and did not see it.
I saw the following free User's Guide for the Lexmark Pro 200 in case that is of any assistance:
https://content.etilize.com/User-Manual/...
